Throttle body gasket question?
Old Jul 3, 2002 | 02:34 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Throttle body gasket question?
My gasket kit came with two differnet gaskets for the TB. One is rubber and very thin and the other is some other type of material but is pretty thick. Do you use both gaskets or just one, and which one? Thanks
Old Jul 3, 2002 | 02:35 PM
scorp508's Avatar
scorp508
What do they look like as there are 3 gaskets used on a TB.
1 for the top plate.
1 for the IAC housing.
1 for the TB to Plenum.
To the plenum I only have one that is made of a gray paper-like material.
Old Jul 3, 2002 | 02:56 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: (scorp508)
Sorry, both the parts I am talking about are for the TB to plenium. One is thin one is thick. I almost think the big one is pressed paper or something, It's deffentally not flexible. I used both and am thinking that that was a bad idea.
Old Jul 3, 2002 | 03:02 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: (85WHITEZ51)
I'd suggest using the paper one. Definitely not both. :eek:
Old Jul 3, 2002 | 06:07 PM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: (War Machine)
Here's a pic of the two gaskets. Which should I use?
Old Jul 3, 2002 | 08:49 PM
ZBRA's Avatar
ZBRA
I always used the black one on my old L98. I doubt either one will make a difference as long as you don't use both.
Old Jul 3, 2002 | 09:14 PM
VetteNoob's Avatar
VetteNoob
One on my car is the black one.
Old Jul 4, 2002 | 04:26 PM
Skippy Stone's Avatar
Skippy Stone
Default Re: Throttle body gasket question? (85WHITEZ51)
If you have a stock TB the black one is a stock gasket.
C-5s hate my car. :smash:
Old Jul 5, 2002 | 11:12 AM
War Machine
Default Re: Throttle body gasket question? (Skippy Stone)
I use the dark gasket like everyone else says.
Old Jul 5, 2002 | 04:11 PM
85 Dave's Avatar
85 Dave
I used the dark one on my 85. :seeya
Old Jul 5, 2002 | 07:12 PM
Corvette0096's Avatar
Corvette0096
Default Re: Throttle body gasket question? (85 Dave)
Old Jul 5, 2002 | 07:17 PM
Lone Ranger's Avatar
Lone Ranger
Same here on my '95 LT1. Sort of like tough stiff fibrous cardboard material or something.
[Modified by Lone Ranger, 5:18 PM 7/5/2002]
Old Jul 5, 2002 | 11:00 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Just did my 88, the gasket was a grayish color and was almost like cardboard. replaced it with the same type gasket from the autoparts store. It was a felpro brand.
So the real answer must lie in what year the car is and what the original gasket you took off is like.
To Throttle body gasket question?
