MSD 8.5s question.
Old Jul 3, 2002 | 02:46 PM
lead_foot's Avatar
lead_foot
Default MSD 8.5s question.
My quess is that the MSD 8.5 ignition wires will not fit into the stock wire looms. What did you guys do to keep the wiring in place? A picture would be worth a 1000 words if you did something special.
Old Jul 3, 2002 | 02:48 PM
scorp508's Avatar
scorp508
A picture huh....
Old Jul 3, 2002 | 02:54 PM
James94LT1's Avatar
James94LT1
Default Re: (scorp508)
I did nothing fancy some black wire ties on the ones that needed to be.
Old Jul 3, 2002 | 03:01 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: MSD 8.5s question. (lead_foot)
www.madeforyouproducts.com Since I don't have centerbolts I used one of the universal kits, and it works beautifully combined with wire ties.
TA's Avatar
TA
Same looms as Scorp's
Old Jul 3, 2002 | 03:05 PM
James94LT1's Avatar
James94LT1
Default Re: MSD 8.5s question. (TA)
Guys,
he has an LT4, optispark, there really isn't looms for them. Your guys look
good thats forsure. But us optispark guys have to run them backwards basically.
Old Jul 3, 2002 | 03:06 PM
tdock's Avatar
tdock
You might want to ream out the stock looms a little with a dremel, so the wires are not as pinched and touching eachother. But the 4 wire square loom under the AC compressor needs a wire tie or two.
[Modified by tdock, 1:08 PM 7/3/2002]
Old Jul 3, 2002 | 03:17 PM
Denney's Avatar
Denney
Default Re: MSD 8.5s question. (tdock)
Hmmmm, I used the stock wire looms on my 94, granted, it took a pair of pliers to close them on the MSD's... Only on a couple of them (like under the alt) did I use a wire tie.
Old Jul 3, 2002 | 07:07 PM
lead_foot's Avatar
lead_foot
Default Re: MSD 8.5s question. (Denney)
Thanks guys for your thoughts. I used the madeforyouproducts looms on my Firebird. They work great. I may try to use their looms with the factory brackets. I'll have to experiment. If I come up with something that works and looks good I'll post it.
To MSD 8.5s question.
