Odd no start issue
Old Oct 1, 2013 | 12:01 AM
ThatGuyCalgary's Avatar
ThatGuyCalgary
Navigator
Default Odd no start issue
Hey guys
Having a very odd no start issue on my '85.
Basically if I sit in it, turn the key to on, and the digital dash comes on, I know it will start.
However, if the dash does not come on, the car will turn over like a SOB, but won't fire. I noticed there is no spark or juice to the fuel pump relay as well.
My immediate guess is ignition switch not powering the ecu or other components, (dash being one of them) however the problem is so darn intermittent, and does not change regardless of steering wheel tilt or ignition wiggling, that I'm slightly puzzled.
Thoughts?
Old Oct 1, 2013 | 12:06 AM
vetteoz's Avatar
vetteoz
Start by checking the switch ( contacts ) operation.Possibly worn from age and not making a good connection each time
The fact you are getting starter operation means the key mech and linkage must be moving the switch at the bottom of the column correctly
Old Oct 1, 2013 | 12:12 AM
ThatGuyCalgary
Navigator
Thanks, I'm glad I'm half on the right track.
Old Oct 1, 2013 | 01:29 AM
Cliff Harris's Avatar
Cliff Harris
The ignition switch at the bottom of the column might be loose in it's mounting location. It has some adjustment for tolerances in the mechanics of the column and the rod that goes from the ignition cylinder down to the switch.
If the switch is loose it could be moving around such that it sometimes works and sometimes doesn't.
To Odd no start issue
