valve spring change
Old Jul 3, 2002 | 04:00 PM
91project's Avatar
91project
Default valve spring change
Is it possible to change the valve springs without removing the heads? :seeya
Old Jul 3, 2002 | 04:04 PM
silver & red CE's Avatar
silver & red CE
Default Re: valve spring change (91project)
I've done it, it's easy to do, just takes time.
Eric
Old Jul 3, 2002 | 06:45 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
yes you need a tool that plugs in the spark plug hole. without it you will have problems. :yesnod:
Old Jul 3, 2002 | 06:55 PM
STL94LT1's Avatar
STL94LT1
You can change the valve springs without removing the spark plugs if you use the TDC method.
Old Jul 4, 2002 | 12:14 PM
89vette's Avatar
89vette
Default Re: valve spring change (STL94LT1)
I did it several times. You fill the cylinder with compressed air. I use my fitting from my compression tester. This will hold the valves up in the head while you change the springs. It takes time and its a PITA for sure.
Jason
Old Jul 4, 2002 | 11:54 PM
Jay Axson's Avatar
Jay Axson
The plugs are a bitch to get at. Get TDC on cyl 1. Do them, rotate crank 90 degrees and go to the next cyl in the firing order. Repeat until done.
To valve spring change
