My stance on this is simple. If you are going to hotrod your car, learn to turn your own wrenches. You'll be assured things are done correctly. If you have to pay someone to do the work; 1) it'll cost a lot, 2) they will iusually screw the job up. Working on cars is not rocket science. If you have a set of tools, and an fsm, you can do 98% of everything related to your car.
I can't see any access from the bottom ? Not on my 1988 anyway with Hedman long tube headers. The bolt would not budge in the rear. So the whole firewall is gonna be cleared.Right now the job is looking at 8-10 hours and he said $500. I figured that much so no surprise.
When I did mine, the last time, I used a ratcheting 9/16 wrench attached to a long belt tensioner wrench. Attached with a liberal amount of the famous silver tape. I was able to get right in between the emission pipe and the head, that's how I got the rear bolt on #8, if that's the one we're talking about. Though I would prefer to find a nice peice of pipe to slip over the wrench next time.
I often make the mistake of not being very clear when I try to say something on here and I apologize. It's not that a wrench can't reach the bolt. The problem is not being able to get enough torque on it to loosen the bolt. If it weren't on so snug I imagine the tiny centimeter turns might get it off eventually ! As it is the decision was made 3 hours sadly to remove the evap box and get a straight shot at the bolt.
I suggest you use an allen bolt when you reinstall. They are easier to torque in tight locations.
I went and picked up my car after work today and Nomore tick tick tick tick tick tick tick Just tires ripping the street. Since the evaporator box came off he went through the entire A/C system. He replaced all the O-rings and the receiver dryer. Charged it up and much colder than before. I'm all set for next summer. Having a $1000 lesson under my belt I won't make the same mistakes again. I will get some tools and start learning to do basic repairs myself.
