code 51 bad ecu?
Old Oct 2, 2013 | 10:09 PM
85corvettec4's Avatar
85corvettec4
Default code 51 bad ecu?
getting a code 51 car was carbed previously
Old Oct 2, 2013 | 10:46 PM
vetteoz's Avatar
vetteoz
http://www.chevythunder.com/codes_5152_55.htm
Old Oct 2, 2013 | 10:47 PM
85corvettec4
also getting codes 25, 32, 33, 34, 35, 36, 41, 43, 46. it would make since if the ecu/prom was bad/redone and now nothings reading but the car was carbureted so i dont understand why anything would have been done with the computer
Old Oct 2, 2013 | 10:56 PM
MrWillys's Avatar
MrWillys
Is the computer there, and does it have a chip installed?
Old Oct 2, 2013 | 10:59 PM
85corvettec4
Ecu is there I'm not sure I bought the car carbed so I'm not sure why it would be .
Old Oct 2, 2013 | 11:06 PM
vetteoz's Avatar
vetteoz
i dont understand why anything would have been done with the computer.
Most remove the computer completely with a carb swap as it no longer serves any purpose
You have so many unknowns and so many problems the only realistic fix would be to buy the factory service manual
then work through each ECM circuit to confirm it is correct and operational
Any help from here is only going to be a guess at best because we have no idea what has been done to your car previously.
We can only help if everything is stock config which you don't know it is
Old Oct 2, 2013 | 11:10 PM
85corvettec4
It is now as I returned the car back to tpi I have a book so.... Wires here I come
Old Oct 3, 2013 | 09:11 PM
85corvettec4
http://forums.corvetteforum.com/c4-t...post1585075995 pictures of the chip and computer
85corvettec4
DELCO HLH 3200 chip
To code 51 bad ecu?
