car wont run with est disconnected
Old Oct 4, 2013 | 10:51 PM
85corvettec4's Avatar
85corvettec4
Default car wont run with est disconnected
ive done this 3 times now. i get the dizzy in perfect. and then itll start up instantly but as soon as i disconnect the red/pink/est wire it dies.
Old Oct 4, 2013 | 11:10 PM
JackDidley's Avatar
JackDidley
My 87 has a tan/black stripe EST wire. Are you sure you have the correct wire ?
Old Oct 4, 2013 | 11:43 PM
Ghast's Avatar
Ghast
Wait, you're setting it and THEN disconnecting it? That's backwards. Disconnect, then set.
Old Oct 5, 2013 | 12:06 AM
85corvettec4
it wont start with it disconnected
Old Oct 5, 2013 | 12:07 AM
85corvettec4
its a redish wire that has the correct connecter for the battery post on the dizzy and then i have the tach filter on the other one marked tach
Old Oct 5, 2013 | 12:25 AM
hooked073's Avatar
hooked073
it is tan with a black tracer
Old Oct 5, 2013 | 12:37 AM
85corvettec4
Old Oct 5, 2013 | 12:41 AM
85corvettec4
this pink wire is the only thing i can find that will attach to the dizzy and was hooked up to the hei when th ecar was carbed im hunting for this tan wire
Old Oct 5, 2013 | 01:05 AM
xrav22's Avatar
xrav22
No you are disconnecting power to the dizzy.Near the wiper motor or a little lower is the Tan wire connector it is a 2.5 inch black plastic you pull apart. It goes to the ecm to retart the timing if there is some knock in the engine.
Old Oct 5, 2013 | 01:13 AM
85corvettec4
PO cut out the black connector and wrapped the wires together and twist capped them. he then proceeded to tuck them away
Old Oct 5, 2013 | 01:17 AM
85corvettec4
Thanks guys! Thread Done.
Old Oct 5, 2013 | 01:18 AM
xrav22's Avatar
xrav22
If you have found it same thing you will just have to undo them. But you don't disconnect the wires from the coil for any reason really
FYI ok done
To car wont run with est disconnected
