L98 Intake Manifold
Old Oct 5, 2013 | 05:52 PM
senorv47's Avatar
senorv47
Default L98 Intake Manifold
could not find anyone to do glass beading on my intake so I have it sandblasted. Is there any prep I need to do prior to reinstallation?
I have an 88 and I had a problem with an intake leak, so I have removed the intake and in the process of cleaning it up and have a few questions:
1. I've been using degreaser, rags and a small brush and while I am making some progress it still needs work. Is there another cleaner I can use to get it done? I'm not in a rush, I want it to look good before
I put it back in?
2. I assume it is aluminum so, once clean, can I paint it up nice and
what type of paint should I use if it can be done?
3. Any other suggestions or advice would be welcomed.
Posted a Picture Below
Thanks in advance
Old Oct 5, 2013 | 06:09 PM
l98tpi's Avatar
l98tpi
Max G’s
You can use a acid and it will clean them nice. Yes you can paint them any color you wish, just use high temp engine paint or find a place that will powder coat them.
Old Oct 5, 2013 | 06:40 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Use some castrol super clean, don't be afraid to 'put it on there's and use rubber gloves. If that is not clean enough, use some etching aluminum wheel cleaner. Again, use rubber gloves. Both items are availabe at your local auto parts store.
Old Oct 5, 2013 | 06:46 PM
MrWillys's Avatar
MrWillys
Carb cleaner, or brake clean followed up with metal prep (acid cleaner).
Old Oct 5, 2013 | 07:17 PM
c4cruiser's Avatar
c4cruiser
You can also use Simple Green in full strength, but don't let it dry. Rinse it completely with hot water after scrubbing.
You can also take to a local machine shop and ask if they will run it through their parts washer. A local engine shop has a machine that will not only clean aluminum parts of all grease and grime but it also takes paint off.
Old Oct 5, 2013 | 09:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Would not use acid on aluminum, can risk some pretty toxic fumes
A machine shop could probably glassbead it for 20-30 will be spotless
Just rinse it REAL good then paint away.
Old Oct 5, 2013 | 09:37 PM
MrWillys's Avatar
MrWillys
All good painters acid etch bare metal, or use a self etching primer. To not etch is leaving dirt on the surface. Blasting does not remove all debris. If your buying paint at Walmart in a spray can please disregard this statement.
Old Oct 6, 2013 | 05:11 PM
senorv47's Avatar
senorv47
I was thinking maybe taking it to a Machine shop and let the experts handle the acid
Old Oct 6, 2013 | 05:14 PM
senorv47's Avatar
senorv47
I asked one of the guy at Autozone and he recommended Purple Power, I tried it and it did not do much. I will look at that Castol Super Clean maybe that will give me a better result.
Old Oct 6, 2013 | 05:16 PM
senorv47's Avatar
senorv47
Did the Carb cleaner and Brake kleen, but did not try the metal Prep.
Old Oct 6, 2013 | 05:17 PM
senorv47's Avatar
senorv47
Thanks I would gladly pay 20-30 to a Machine Shop
Old Oct 6, 2013 | 05:25 PM
senorv47's Avatar
senorv47
Here is what I am working with:
Here is an updated picture as I work to clean it up
Could not find anyone that did Glass beading in my local area so had the intake sandblasted, what prep to I need to do before reinstallation?
Old Oct 6, 2013 | 09:16 PM
DanZ51's Avatar
DanZ51
I was gonna recommend NAPA 1458 aluminum brightener. (which is an acid cleaner)
But you may have to have that bead blasted to get that pitting off.
Old Oct 6, 2013 | 11:46 PM
Cliff Harris's Avatar
Cliff Harris
I used 409 on mine.
Old Oct 7, 2013 | 01:39 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
So easy a caveman can do it!
Douse with your favorite cleaner. I like Awesome from the Dollar store.
Hit it with a power washer or the quarter car wash.
Spray with your favorite rattle can paint.
Save your money for things more important.
PS by the time you put everything back together, that manifold is BURIED!
Old Oct 7, 2013 | 08:11 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
I used purple power on mine, I soaked the hole thing in 5 gallons of it for a week and it removed all the carbon, same with the plenum and runners.
Old Oct 7, 2013 | 06:29 PM
senorv47's Avatar
senorv47
Sent out to get blasted
To L98 Intake Manifold
Old Oct 7, 2013 | 06:33 PM
senorv47's Avatar
senorv47
Sent the Intake out to get blasted ($20, not bad) will post updated pic when I get it back.
Read a post with regard to the front and rear seals on the intake. The post recommended using a bead of silicone instead of the rubber seals? Any confirmation on this from anyone?
Old Oct 7, 2013 | 10:56 PM
l98tpi's Avatar
l98tpi
Max G’s
This is true. Use a high temp, oil resistant sealer. Permatex makes a good one or you can get GM Engine sealer from your local Chevy Dealer parts dept. it is good stuff.
Old Oct 7, 2013 | 11:23 PM
eutu1984's Avatar
eutu1984
The seals on the front and rear of the intake referred to as the china walls should be dimpled with a punch or drill bit, that will help keep the sealer in place. Thats what I did and I have not had a leak since.
