UEGO Five wire Oxygen O2 sensor
Old Jul 3, 2002 | 11:18 PM
dsagers's Avatar
dsagers
Default UEGO Five wire Oxygen O2 sensor
Anyone know the difference between a UEGO 5 wire and a typical 3 or 4 wire O2 sensor?
Wondering if there are enough advantages, and if I can even replace a 3 or 4 wire O2 sensor with a 5 wire sensor?
I know where the wires connect on a 4 wire, how are the five wires connected?
Old Jul 4, 2002 | 12:36 PM
DOCTOR J's Avatar
DOCTOR J
Default Re: UEGO Five wire Oxygen O2 sensor (dsagers)
An EGO is a basic O2 sensor found in most modern cars; UEGO is a two-cell Wide Band (WB) system.
Their applications are very different, and the two are not interchangable without a lot of rework on the average GM ECM program, and/or some electronic fabrication.
Basic info on EGO can be found here:
http://www.parttrackers.com/library/1/
Look in section 3.
Specific EGO article here:
http://www.parttrackers.com/library/1/24/27/
Info on a WB design is here:
http://www.diy-efi.org/diy_efi/projects/diy_wb/
There are more articles around but I don't have the references handy right now. You can also use the "Search" button and look in this section of the Forum.
HTH
DrJ
Old Jul 4, 2002 | 01:00 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: UEGO Five wire Oxygen O2 sensor (DOCTOR J)
Yep. My WB has 5 wires.
pos
neg
ground
cal resistor +
cal resistor -
Old Jul 4, 2002 | 01:34 PM
dsagers's Avatar
dsagers
Great info guys, thanks for the links.
To UEGO Five wire Oxygen O2 sensor
