84 hose/elbow found loe not connected
Old Oct 10, 2013 | 04:25 PM
ToniJ1960's Avatar
ToniJ1960
Default 84 hose/elbow found loose not connected
I found a rubber/ plastic accordian sort of elbow fitting laying loose under the hood. It was laying between the edge of the air cleaner cover and the ac compressor. Looking around I noticed, theres a steel elbow at the top of the ac compressor that goes to a diaphragm I guess it is. On the back of the diaphragm facing the rear of the car is a metal nipple. Nothing is attached over that pipe/nipple/ Could this be where the short plastic pipe came off of?
Old Oct 10, 2013 | 08:33 PM
garryowen's Avatar
garryowen
sounds like the blow off line that vents the smog pump. it runs from the smog pump to the front of the air cleaner on a stock 84 cross fire
Old Oct 10, 2013 | 09:22 PM
ToniJ1960's Avatar
ToniJ1960
Any real concern about putting it back on?
Old Oct 11, 2013 | 01:03 PM
gwbutch's Avatar
gwbutch
It won't matter a whole lot if you leave the smog pump hooked up or not.
Old Oct 12, 2013 | 01:16 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Don't know where you're located, but if you need to pass a smog test, you'll probably fail with this hose not in the right place. It's easy to install. Remove the top cover of the air cleaner and you'll see the hole in the front of the air cleaner bottom housing.
To 84 hose/elbow found loe not connected
