What Chip for my set up?
Old Jul 4, 2002 | 05:57 PM
Gareth's Avatar
Gareth
Default What Chip for my set up?
I think I'm down on power from what I expect from these mods, need a chip Help!
Car Spec
1988 Corvette Z51 4+3 Manual
Current Mods
Adjustable Fuel Pressure regulator
K & N Filter with cut lid and removed MAF Gauze
Ported cylinder heads (gasket matched)
Ported stock headers (gasket matched)
Comp Cams Grind: 264 Lift: .487''/.495'' RPM Range: 1200-5200
Comp Cams Magnum 1.6 ratio, 3/8'' Self Aligning Roller rockers
Comp Cams Up-rated springs
Comp Cams 5/16'' (Heat Treated) Push rods
Crane Roller timing chain
Cheers
:smash:
Old Jul 4, 2002 | 06:07 PM
gbody5's Avatar
gbody5
Default Re: What Chip for my set up? (Gareth)
Any exhaust modifications? Seems that is in order before any PROM modifications.
Old Jul 4, 2002 | 06:15 PM
Gareth's Avatar
Gareth
Default Re: What Chip for my set up? (gbody5)
I've ported out the exhaust manifold to suit the heads but that's it.
Old Jul 4, 2002 | 06:28 PM
gbody5's Avatar
gbody5
I would look into a low restriction exhaust system from one of the aftermarket suppliers first, then give it a complete tune-up, including setting the timing and all that, if you have not already.
As for Chips, the concensus on this forum seems to be staying away from the generic Chips and having someone with experience on tuning these cars make a custom chip for you liking.
Best of Luck
Old Jul 4, 2002 | 06:35 PM
Gareth's Avatar
Gareth
ok, but this could be a problem in England, do you know of anywhere I could buy online, with a good help desk!?
Old Jul 4, 2002 | 06:47 PM
gbody5's Avatar
gbody5
http://www.corsaperf.com/autohome.htm http://www.borla.com/ http://www.madvet.com/ http://www.ecklers.com/
Don't know a thing about shipping overseas ole chap, but a good exhaust shop may also be able to fabricate something up for you.
Also don't know what your emissions regulations are and if your car is set-up differently than a US based model, but regardless, less back pressure than the OEM exhaust will help, esp. with your engine mods.
Old Jul 4, 2002 | 06:55 PM
vader86's Avatar
vader86
You will need some type of better exhaust work to get the most power, like headers. Hooker, TPiS, Lingenfelter all make good ones.
As for chips, youll need a custom burn, and i would try http://www.fastchip.com
Ed makes the best.
To What Chip for my set up?
