[4+3]: Split up my old one today.
Anyways the overdrive unit on my original tranny an MK2 0.68:1 unit was still good at the time I pulled it out at 166k miles. So the idea now is to swap that one onto the good ST-10 in the car now since the original ST-10 blew up two teeth on the cluster gear inside of it.
Draining the ST-10 of it's gear oil.
A whole ton of metal chips, flakes, and other misc grunge on the magnetic drain plug.
The two gear teeth sheered off from the cluster gear (rearmost gear for 1st and reverse).
Split apart, nice and clean huh?! :) (p.s. That is a 454 crankshaft on the lathe under the towel. :D)
OD unit.
Driver's side of ST-10 with side cover off.
Tailshaft of ST-10.
OD unit in our parts tank.
OD unit looking a little better.
Same.
Where the two teeth sheered off.
Both cleaned up.
Same.
Same.
Here is an old pic from when I originally pulled it out of the car.
[Modified by scorp508, 7:24 PM 7/4/2002]
That, the sand blaster, the lathes, the air compressor, and the press make things really easy sometimes.
Are you going to rebuild the other one so you can have another replacement waiting? I think I would, never know when something bad is going to happen.
My garage has a lot of tools, but no parts tank. Sometimes something like that would just be handy. Best of luck on getting it back together ASAP.
:cheers:
:D
