Help with Speed Sensor Gear
Old Oct 15, 2013 | 07:25 PM
mikeysee1's Avatar
mikeysee1
8th Gear
Default Help with Speed Sensor Gear
My speedometer crapped out the other day on my '85 on my way home. I removed the speed sensor and the center of the plastic gear had a groove worn in it. After searching the internet and calling a few trans shop I found a used 42 tooth gear and it didn't match exactly to the old one. The inside of the cone had a raise lip that I will have to grind down to make it work. Is there a reason it is so hard to find a gear for the 700R4 that exactly matches. Also my speedometer is off, when it reads 40mph I'm really going 43-44mph. The guy at the trans shop said I need to find a gear with less teeth, Is that true? Any help on this matter would be greatly appreciated.
Old Oct 15, 2013 | 07:40 PM
MrWillys's Avatar
MrWillys
http://www.transmissioncenter.net/sp...n_______va.htm
Old Oct 15, 2013 | 09:27 PM
WVZR-1's Avatar
WVZR-1
Post the rear axle ratio of your car, the tire size and let's see if we can sort your situation for you. Post a snapshot of your worn gear so the damage can be seen. The "picture is more valuable than 1000 words" definitely applies here.
Once the speedometer is actually working again then it would easier to help you if you could post your speedometers reading when doing 45 mph, 50 mph, 60 mph, 70 mph with a GPS. We need to establish a % of error to be able to correct it.
I wouldn't worry about vendors until you understand the damage to what you have. Have you changed the rear axle gears? Was it changed before you? The more information you can supply the easier it will be to help you.
What color is your VSS? White or black are your choices!
To Help with Speed Sensor Gear
