A/C Compressor and Freon Leak??
Old Jul 5, 2002 | 12:02 AM
RJVette23's Avatar
RJVette23
Default A/C Compressor and Freon Leak??
I was working on my vette today and experienced something I thought was very strange.....
As the engine ran the A/C Compressor would release what I assume to be freon in short bursts....like pressure from a valve.
The A/C also quit blowing cold today. Is the compressor shot? Low on refrigerant?? or what??
Any Ideas????
Thanks in advance for the help.
Happy 4th of July,
RJVETTE23 :flag
Old Jul 5, 2002 | 01:41 AM
hotwilzz's Avatar
hotwilzz
Default Re: A/C Compressor and Freon Leak?? (RJVette23)
If we are talking about the same thing, its a very loud, scary sound, at least it was for me with my head under the hood. Anyway, if that is whats happening it is indeed a vent to relieve unwanted pressure from the system. In my case I had replaced the oriface tube filter and evidently bent it puting the line back together, which didn't allow to system to flow properly and thus the venting. You may just need to have some routine service, i.e. new oriface filter, pull a vacuum and recharge the system. worst case if the compressor let go and clogged the filter with fallout you may have to replace the compressor
good luck
david
[Modified by hotwilzz, 12:41 AM 7/5/2002]
Old Jul 5, 2002 | 10:16 AM
RJVette23's Avatar
RJVette23
Default Re: A/C Compressor and Freon Leak?? (hotwilzz)
David,
Thanks for the reply :flag
To A/C Compressor and Freon Leak??
