TPI runners interchange years
Old Oct 17, 2013 | 05:35 PM
ghoastrider1's Avatar
ghoastrider1
Default TPI runners interchange years
do 91/92 runners of a trans am TPI interchange? thanks.
Old Oct 17, 2013 | 06:13 PM
vetteoz's Avatar
vetteoz
Originally Posted by ghoastrider1
do 91/92 runners of a trans am TPI interchange?.
With what ????????
Old Oct 17, 2013 | 06:32 PM
MrWillys's Avatar
MrWillys
All TPI runners will interchange. However, 89 thru 92 will not have provisions for the cold start injector if used on 85 thru 88 systems.
Old Oct 17, 2013 | 06:37 PM
ghoastrider1
thank you sir.
Old Oct 17, 2013 | 07:39 PM
UNCLEBILL's Avatar
UNCLEBILL
thank you sir.
Accel used to have a 9th injector delete kit. A plug for the injector and a cap for the fuel rail. Did this to my 1988 Formula 350 Firebird (sons car now). Never found it a problem deleting the 9th injector.
Bill
Old Oct 18, 2013 | 03:40 PM
Baller's Avatar
Baller
Also check the EGR. I replaced my 90 tubes with Accells street runners for an 88-89 and they had EGR connections on both sides so I had to plug the drivers side to stop a huge vacuum leak. 990 Runners don't have a drivers side EGR tube.
1988
1990
Old Oct 18, 2013 | 06:12 PM
vetteoz's Avatar
vetteoz
Nope.
The drivers side tube is the IAC feed direct into the TPI base for the cold start injector used on the early cars as mentioned above
'89+ runners; no CSI so no drv side tube
Old Oct 18, 2013 | 06:37 PM
Baller's Avatar
Baller
Originally Posted by vetteoz
Nope.
In either case if you don't have the matching plenum from the same year you can get one huge vacuum leak. So OP, check to make sure the plenum matches the runners because there is a difference between years. In my case it was easy enough to just plug the tube and seal it.
To TPI runners interchange years
