Tach Trouble..Reads High
Old Oct 18, 2013 | 11:28 PM
fatboywilly's Avatar
fatboywilly
Default Tach Trouble..Reads High
I have a 90 L98. The tach reads about 300 rpms high at idle and a thousand rpms high at 70 mph. Any ideas or suggestions? I bought another used one and it reads about 200 and 800 too high. Resistor? ECM?
Old Oct 19, 2013 | 10:34 AM
DBo's Avatar
DBo
Bit of a long shot, but cheap. You might try a tach filter. Runs off of the distributor. I had a similar problem with my 84 and that fixed it.
Old Oct 19, 2013 | 12:40 PM
WVZR-1's Avatar
WVZR-1
Check the information at the ALDL with a capable scanner. If the scanner information is correct/more realistic than the cluster tach your cluster needs repaired/rebuilt for calibration.
Old Oct 19, 2013 | 11:44 PM
fatboywilly
Pulled it out. Cut the resistor at 2 points and installed new 300 Kohm resistor and it reads right on now. Also did a 91 cluster.
To Tach Trouble..Reads High
