"SYS" flash
Old Oct 20, 2013 | 12:43 AM
hgoodwiniii's Avatar
hgoodwiniii
Default "SYS" flash
Hi all, I am getting a "SYS" flashing indicator in my speedometor. The flash indicator rolls between my "MPG" and flashes about 3 times every few minutes. Can anyone let me know what I need to do to diagnose this? Thanks.
Old Oct 20, 2013 | 12:58 AM
Silver96ce's Avatar
Silver96ce
Charging system problem. Try checking cable connections at battery for corrosion and if battery is not too old, charge it.
Old Oct 20, 2013 | 02:47 AM
vetteoz's Avatar
vetteoz
http://forums.corvetteforum.com/c4-t...ashes-sys.html
Old Oct 20, 2013 | 08:46 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
But one other possibility to list.
What year is your car?
Have you just installed an aftermarket audio system?
If you haven't, then a low/bad battery and/or connection is what to look for.
Old Oct 20, 2013 | 09:48 AM
AirForceOne!'s Avatar
AirForceOne!
When's the last time you drove her? Mine had the same problem last winter when I couldn't drive it for 3 weeks. Ended up being the battery needing a charge. Bought a battery tender and never had the problem again.
Old Oct 20, 2013 | 12:28 PM
hgoodwiniii
It's a 91. I've been driving it regular for the past month. Battery is fairly new. I'll have it tested along wth alternator. Thanks.
Old Oct 20, 2013 | 08:50 PM
vl5150's Avatar
vl5150
Have you been into the ECU? I didn't seat the memcal correctly and I got this message on mine.
To "SYS" flash
