Battery Drain
Old Oct 21, 2013 | 10:45 AM
blue67ragtop's Avatar
blue67ragtop
2018 C2 of Year Finalist
Default Battery Drain
I have an 88 coupe that the battery will completely drain on in about a week if the car isn't driven. The charging system works fine and as long as the car is driven or started every couple of days it won't go flat. The battery is less than a year old so I think the problem is elsewhere. I will test the battery but wonder where else I should be looking as a possible problem. I went in the garage the other night and did see the courtesy lights flashing and the "rear hatch" annunciator flashing. It didn't seem to be adjar but after reclosing it the lights went out. That is the only time I have observed that and it might be unrelated. Thanks for any input.
Old Oct 21, 2013 | 12:50 PM
davewhtt's Avatar
davewhtt
I was getting a battery drain and it turned out to be a bad door a jar switch was broke.
Old Oct 21, 2013 | 01:19 PM
don hall's Avatar
don hall
Originally Posted by blue67ragtop
........ I went in the garage the other night and did see the courtesy lights flashing and the "rear hatch" annunciator flashing..........
Similar solution to what davewhtt posted above:
http://www.justanswer.com/chevy/3ujs...oors-hood.html
Old Oct 21, 2013 | 05:43 PM
playsdixie's Avatar
playsdixie
just went through this with my 85 ...spent way too much unnecessary time....checking at night for lights on is the 1st and easiest...otherwise put a meter on the neg post and cable and pull fuses until the voltage drops...at least then you'll know what circuit it's in...my mistake was not knowing putting the cable and post in series with my meter makes the cts lites come on....you have to wait until they go off to check the voltage drop..(assuming they are going off..) based on your post...good luck,
Old Oct 21, 2013 | 07:49 PM
vetteoz's Avatar
vetteoz
There are also power feeds direct off the battery that don't go through the fuse box and can draw power if they fault ;
the headlight motors not hitting their limit switch and drawing power is a common problem.
Those supply wires need to be removed from the terminal behind the battery and metered individually.
Old Oct 22, 2013 | 01:27 AM
rhinoevans's Avatar
rhinoevans
I have no idea how to do this check. Can you go into more detail on how you check with a meter. Exactly where do you put what to check?
Old Oct 22, 2013 | 02:03 AM
Cliff Harris's Avatar
Cliff Harris
You put the meter in current mode and disconnect the battery cable. Then you connect the meter between the battery and the cable. If you draw more than 10 amps you will blow the current fuse inside the meter. These are special fuses ($$$$$) and must be replaced with the correct fuse or the current function reading will be WAY off.
As playsdixie said, when you open and close the battery circuit the courtesy lights will come on, so you need to wait a minute for them to go off before reading the current.
There are some circuits that always have power on them so there is going to be a small current draw even with cars that are OK. The main ones are:
ECM (remembers error codes and BLMs),
dashboard (remembers your average mileage and trip odometer),
radio (remembers station settings and time),
electronic HVAC (remembers temperature and function settings).
Old Oct 22, 2013 | 02:13 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Normal current readings are 50 milliamps or less.. (.5 amps)
Old Oct 22, 2013 | 07:29 AM
WW7's Avatar
WW7
If Im not mistaken I think it's ( .05 ) for 50 milliamps...WW
Old Oct 22, 2013 | 11:51 AM
ccrazor's Avatar
ccrazor
Originally Posted by ww7
if im not mistaken i think it's ( .05 ) for 50 milliamps...ww
oops.. :d
Old Oct 22, 2013 | 10:11 PM
blue67ragtop
Thanks for all the replies, some real good info here. Although I haven't located the problem yet I'm inclined to believe the door ajar switch is the culprit. When I bought the car I noticed that several of the screws were missing from the left door panel and it looked as if it may have been removed. The car also had a new battery which probably indicates the previous owner was trying to track down the same issue. Thanks again.
Old Oct 23, 2013 | 03:01 PM
dogfish246's Avatar
dogfish246
This might help you diagnose the problem. I made this video to help others find a potential short in their car:
To Battery Drain
