[4+3]: Overdrive Rebuild Tutorial
Old Jul 5, 2002 | 07:42 PM
scorp508's Avatar
scorp508
Default [4+3]: Overdrive Rebuild Tutorial
Who has the link to David's tutorial on rebuilding the OD? I need to see if I can do this myself without any clutch drum compressors and don't have the link here. Might have to rebuild one TONIGHT and swap trannies tomorrow for a race.
Old Jul 5, 2002 | 08:41 PM
HighHopes85's Avatar
HighHopes85
Default Re: [4+3]: Overdrive Rebuild Tutorial (scorp508)
Don't have the link but...
I rebuilt my 700R4 in the past. I didn't have any $$$ for expensive tools so I made all my compressors out of all-thread and 3/8" steel. A cutoff tool was quite handy. So was a nice sharp drill bit and plenty of nuts that fit the all thread.
Old Jul 5, 2002 | 08:44 PM
scorp508's Avatar
scorp508
Thanks.
I found my printed out copy of it. Doesn't look like I"ll be doing it at home tonight. :)
Old Jul 5, 2002 | 10:20 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (scorp508)
Man scorp.....
It sure sucks to be out of commission, doesn't it?
I am becoming a figit freak :lol:
You'll get there....
Old Jul 5, 2002 | 11:33 PM
scorp508's Avatar
scorp508
Default Re: (ski_dwn_it)
Only for highway cruising and speeds in excess of 145. :) I just got back from the local pub, took the vette. She's find for anything that only uses up to 4th.
Old Jul 5, 2002 | 11:57 PM
LT5's Avatar
LT5
Thats sux....I know how you feel. :yesnod: Tommorow I'm going to replace the starter on my LT5! :( :cry
Old Jul 6, 2002 | 03:09 PM
frank moran's Avatar
frank moran
Scorp, your my kind of guy, jump right in there. Been following your saga's for awhile (went the TT Z route for awhile, prefer the vette ) anyway, if you have the rebuild tutorial I'd like to see it also. Another source to consider is the popular mech cd, they are quite good, same as GM factory manual....
I am looking at a rough 85 with a 4/3 ,the OD is not working , light throttle disengages it, but my concern is the qvailability of hard parts if I need them, what has your experience been, how do you rate this trans. I hear all the horror stories but half are probebly the result of incompetent people working on them. I have had many vetteeee auto's but I want a stick.
Old Jul 6, 2002 | 03:50 PM
scorp508's Avatar
scorp508
I love the trans. As long as they are taken care of, and you change the fluids & filter reguarly they seem to be fine for a looong time. My original one had 166k on it before I sheered 2 gears off of the 1st gear cluster gear inside the 4-speed.
Old Jul 6, 2002 | 04:34 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
You can always make spring compressors with PVC pipe, some threaded rod and appropriate nuts, some angle iron and a little imagination. All for under 10 bucks at your local Home depot or equ.
Old Jul 6, 2002 | 07:27 PM
bogus's Avatar
bogus
Default Re: [4+3]: Overdrive Rebuild Tutorial (AquaMetallic94LT1)
what happend to the overdrive? I am out of the loop here... missed a couple of days... :D
LT5 - I don't envy you that starter swap... thats a LOT of bolts to remove... ick...
Old Jul 7, 2002 | 08:25 AM
rodj's Avatar
rodj
If it ain't too late try this http://corvetteactioncenter.com/foru...threadid=10459
To [4+3]: Overdrive Rebuild Tutorial
