94 starting issues
Codes I pulled are (1) h31 to 38 (4) 41 (9) h42
It was running perfect then suddenly wouldn't start.
It did have a bad battery that i am guessing are from the h codes
Any body else have an idea?
DTC 41 in the module 4 ( the ECM ) loss of serial data from the CCM to the ECM.
If the ECM does not get the signal from the CCM on that circuit to fire the injectors, the engine won't fire
A very hard to identify problem.
Multiple potential causes , bad connection(s) , bad grounds , faulty CCM
Start here
http://forums.corvetteforum.com/1554492041-post15.html
http://www.digitalcorvettes.com/foru...5&postcount=17
http://forums.corvetteforum.com/1554993058-post25.html
http://forums.corvetteforum.com/1555985163-post33.html
http://forums.corvetteforum.com/c4-t...wes-is-me.html
FWIW
31 - 38 in module 1 ( the CCM ) are all (H = past ) data circuit related faults so maybe you are lucky and only have a faulty CCM.
DTC 41 - Ignition Control (IC) Circuit (Open Circuit) - See more at: http://tech.corvettecentral.com/2011....7yLrzUBa.dpuf
This is an old training film but comes in handy.. pay attention to [14:35]
http://www.youtube.com/watch?v=lFCja...ature=youtu.be
I would clear all codes and try a start up.. if you go to DTC41 in the FSM it will give a fault tree for further trouble shooting.
Not sure what all you had to do with your weak battery, but if you did any "Jumping" this could have played havic with your electrical system.
