experience with 700r4 shift kit?
Old Oct 25, 2013 | 03:30 PM
85corvettec4's Avatar
85corvettec4
Default experience with 700r4 shift kit?
how does everyone like the benefits of an upgraded shift kit in their 700r4?
Old Oct 25, 2013 | 07:06 PM
mxw128's Avatar
mxw128
Installed 2 shift kits in 700R4s, both B&M Super Trans Packs, one in an 83 Trans Am and one in an 84. I liked them, they really firmed up the shifts (I could chirp first through 3rd) and I liked the torque converter lockup switch. Had the 84 for 10+ years until I sold it and never had a problem with the transmission with the kit installed.
Old Oct 25, 2013 | 08:51 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'll give it
I've used the Transgo and B&M.
The Transgo is more driveline friendly when shifting at part throttle.
Old Oct 25, 2013 | 08:56 PM
85corvettec4
doesnt B&M have some hardware as well?
Old Oct 26, 2013 | 03:11 AM
Cliff Harris's Avatar
Cliff Harris
A friend of mine had his trans built by B&M twice at their place. Blew up twice. He had no problems after Art Carr rebuilt it. Art said people like the 2nd gear chirp they get from B&M but it breaks things. He said the way to go is to firm up the shifts but not go too far and get the bang bang shifts.
Old Oct 26, 2013 | 12:06 PM
Epitome's Avatar
Epitome
Great did a bunch of research before I just installed a B+M shift kit. At wide open throttle it does bark the tires. In drive, without shifting it by hand from first to second it will never chirp the tires because it shift at such a low rpm (except wot). If I shift manually from first to second at part throttle it does shift hard with maybe a minor chirp. No noticeable chirp ever happens, under any conditions from second to third. My car is an all original 70k mile 1990 with no modifications. I have figured that since I am keeping it all stock a shift kit would be a good thing for the transmission and I thought with stock only power the D36 rear would be fine. I never ever hit the pedal hard except on a straight away. I would think hard hits and shifts in turns are what could really hurt the rear. What does everyone think?
Old Oct 26, 2013 | 12:08 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Old Oct 27, 2013 | 07:40 AM
vetteoz's Avatar
vetteoz
When Art Carr speced my trans ( built using all his parts and shift kit ) he advised against fitting the .500 boost valve popular with many builders because he said it made the shifts too hard and that was for my trans intended primarily for the strip.
Old Oct 27, 2013 | 12:15 PM
85corvettec4
my cars all stock but the poor gearbox is failing after about 30 years of duty. ive always wanted to install a shift kit so im kind of "excited" for it to fail
Old Nov 3, 2013 | 12:10 PM
pricesgarage's Avatar
pricesgarage
a shift kit will not fix a bad or weak transmission if a vette trans is in good working order it doesnt need much mods on a stock cf or l98 far as shift kits use a b and m kit but use a stock 1-2 accumlator sping or a 2-3 spring from a th 350 block the 4th gear on and drill the plate as the directons state a .500 boost valve is a good idea but if the trans is slipping or flaring you need to get it rebuilt
Old Nov 3, 2013 | 12:39 PM
85corvettec4
Oh ya I was going to go get a fresh one. It doesn't slip or anything but she shoves hard when you go into D/R
Old Nov 4, 2013 | 12:27 PM
Deakins's Avatar
Deakins
Most of the 700R4/4L60's that I've been around that had shift kits in them and some HP/traction all ended up destroying the planetary gear set. When the transmission engages that hard it loads the gear set up pretty bad. Hence why you see a common upgrade to the 5 gear set over the usual 4 gear unit that the vette transmissions had.
If you have some HP and tires and plan on running the car hard I would stay away from the kits that hit that hard. A well timed, fast shift that won't burn up the trans is the way to go. Just my .02
Old Nov 10, 2013 | 04:31 PM
jstkrsn's Avatar
jstkrsn
I put the B&N Shift kit in my 92 Vette. It bangs a little from first to second when driving slow, but really slams it when going fast. There are two settings, I used the trailer towing one not the hard core one. I had also put the same kit in a Turbo 350 tranny, it banged into gear when putting it into reverse. So it seems there are some disadvantages to the kit depending on application. But it does firm all the shifts.
Old Nov 10, 2013 | 04:36 PM
85corvettec4
so it makes the shifts better but it lowers the health of the tranny?
Old Nov 10, 2013 | 05:53 PM
91tpiman's Avatar
91tpiman
Shift kits are nice, but you would really benefit more by having the Torque converter lockup settings changed in the chip as well.
Old Nov 11, 2013 | 03:23 AM
Cliff Harris
The main purpose of the shift kits is to firm up the shifts. This helps the trans clutches (the weakest link) to last longer. Usually the pump pressure is also increased, which also helps the clutches last longer.
I looked at the 5 gear planetaries. When I saw the price I said I'm done here...
To experience with 700r4 shift kit?
