loctite
Old Oct 27, 2013 | 10:03 AM
tideferi's Avatar
tideferi
Default loctite
another question
do you put some loctite on the oïl pump bolt and also on the ring gear bolt.
thanks
Old Oct 27, 2013 | 12:26 PM
383vett's Avatar
383vett
Are you bolting the oil pump onto the ring gear? Actually the answers are no and yes.
Old Oct 27, 2013 | 06:14 PM
tideferi's Avatar
tideferi
no its two different questions.............
Old Oct 28, 2013 | 08:07 AM
blackozvet's Avatar
blackozvet
I used loctite on the oil pump stud and the bolts on the ring-gear (flexplate)
Old Oct 28, 2013 | 10:22 PM
383vett's Avatar
383vett
Ring gear in the differential?
To loctite
