fuel injector connector
Old Oct 27, 2013 | 07:13 PM
nivensid's Avatar
nivensid
Default fuel injector connector
Two of the fuel injector connectors on my 87 coupe look to have seen their better days. Some of the wires had worn through the insulation, I temporarily covered the wires with some liquid tape. The motor runs strong with no miss currently.
How difficult is it to replace the connectors into the harness? I can solder no problem, just wondering how difficult it will be to get to the spot on the harness where the connector joins. Is the factory connection a soldered joint?
I looked in my FSM but no luck.
Old Oct 27, 2013 | 07:26 PM
vetteoz's Avatar
vetteoz
You just have to open the injector harness up and expose the factory joints
IIRC , the joints are crimped
