I've got an 87 vette that had a cracked block. I had a 350 short block already rebuilt, bored .30 with flat top pistons. 212@.50 or .214@.50 flat tap cam. I had the 113 heads redone put long tube headers on with a 2400 stall. I eliminated air pump, ran true duel exhaust with no cat. Changed the o2 sensor to a 4 wire. I sent the chip to be reprogrammed and installed it. My problem is! It is running rich at idle. when your trying to drive at a steady speed it acts like its running out of gas. Press on the throttle a little and it takes off. It will do this until the SES light comes on! Then it runs like a dream. I don't know how to check the code when the light is on or how to data log. Please tell me what to do! Every time I shut the car off the computer resets.
Reason: Changed wording
I also cannot find the connecter under the dash for the diagnostic plug or to check the code it is throwing.
The connector is under the dash just to the right of the steering wheel. It's rectangular shaped, about 2 inches wide and has 12 pins. Use a paper clip or wire to connect the two upper right hand pins together. Turn the key on. The check engine light should blink. It should first show a Code 12. It will blink once (1) then pause and blink twice (2). The code 12 will be displayed 3 times. The blinks that come after that are the fault codes. For instance, Code 21 will blink twice, pause and blink once. Each fault code will be displayed 3 times. When all codes have been displayed it will repeat code 12.
Found the plug. stuffed up in the wiring behind the radio all tangled up. Remounted it where it belongs. I'll check those codes tomorrow night and post what I find out. Thanks for the help.
This Datamaster guide is for a turbo truck http://powertuneplus.com/syclone/tunersguide_dm.shtm
( some items shown don't apply to our cars )
but it shows you what the datalog lets you see when you play back the recording
You can do the playback through Datamaster as well.
I think your initial problem is your changes are way outside a normal engine so it's going to take lots of logging, chip burning, more logging, chip burning, etc to get your rig where it needs to be. One and done chip isn't going to cut it. I used the Moates Auto Tune and highly recommend it.
Go you have an adjustable fuel pressure regular? What's your fuel pressure? Did you increase the injectors? Lots of reasons in play to give you performance problems at this point.
When you do the UNI playback open the histogram and click L-term counts to get a good idea of what's going on.
