Yet Another "Remove the Frisbee" Question
Old Jul 6, 2002 | 09:33 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Yet Another "Remove the Frisbee" Question
OK, whats the trick?
I removed the 4 nuts holding it on, but it won't come off!
Help!?!
Old Jul 6, 2002 | 12:08 PM
Wheelman's Avatar
Wheelman
Default Re: Yet Another "Remove the Frisbee" Question (jaa1988)
on mine i just kept spinning the frisbee the opposite way of the waterpump and eventually it came off. If you have one of those belt style grippers to put on the water pump that might help. Also, make sure you put some lock washers on the bolts when you put them back in, and check them after a week or two to make sure they are still tight. :cheers:
Old Jul 6, 2002 | 01:10 PM
DON M's Avatar
DON M
I had to tap mine "lightly" with a hammer to break it free.
Old Jul 6, 2002 | 02:24 PM
corvettekid872002's Avatar
corvettekid872002
Cruising
what is the frisbee and where is it?
Old Jul 6, 2002 | 03:03 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Default Re: Yet Another "Remove the Frisbee" Question (DON M)
I was afeared to tap it, so I'll try that the next time I'm working on the car.
I'm exhausted from replacing the heater hoses, pulling and cleaning the radiator, replacing the plugs, wires, cap, rotor and coil.
Damn does it run better :D :D :D
For the guy asking about the frisbee, its on L98 engines only. It seems to have appeared on the 88 and up cars. According to Gordon Killebrew it is not required and can be removed. Its called a "frisbee" because on the 88 it looks just like a flat disc frisbee.
Old Jul 6, 2002 | 04:20 PM
needanother1's Avatar
needanother1
It's on the front of the water pump pulley--- About 10 lbs of excess rotating mass. I removed mine last night and hung it on the garage wall so everyone can ask "What the---". ;)
Jason
Old Jul 6, 2002 | 04:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First off I assume you had the serpentine off the pulley.
Your "frisbee" is solid steel and weighs about 10lbs so just smack it with a small ball peen on the back side a copla times.
I did my "frisbee" delete while changing the water pump so used channel locks to remove the four studs and replaced them with bolts and lock washers for a neater appearance. I also used some thread lock to assure they would stay put till I wanted them out.
Old Jul 9, 2002 | 10:20 PM
jjmac_dragracing's Avatar
jjmac_dragracing
Default Re: Yet Another "Remove the Frisbee" Question (65Z01)
I have a 85 do I have a frisbee :confused:
Old Jul 9, 2002 | 11:27 PM
Skippy Stone's Avatar
Skippy Stone
You'll never put it back on, right? So beat it, pull it, pry it with screwdrivers, who cares - it's trash. If you bang it up enough you can tell everone you blew the engine dragging a viper. Worth stud points, I think. :jester
Old Jul 10, 2002 | 01:05 AM
needanother1
Default Re: Yet Another "Remove the Frisbee" Question (jjmac_dragracing)
No. Seems to have appeared on '88 and newer L98's when they started using the Nippondenso A/C compressor.
Jason
Old Jul 10, 2002 | 05:45 PM
ZAD54's Avatar
ZAD54
Its kind of like unwanted house guest, the longer its been there, the harder it is to get them to leave; or in this case the harder it is to get it off. I rocked mine back and forth and got it moving a little and then gave it a good smacl (also works for the unwanter house guests) and it came right off. Its alot heavier than it looks, thats why it takes so much force to get it off. :seeya
Old Jul 10, 2002 | 07:12 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Yet Another "Remove the Frisbee" Question (ZAD54)
Mine just popped off. Once I loosened all 4 nuts, a little at a time I might add, it almost fell off. Then when I went to grab it, it did fall off, lol. Was waaaaaaaaaay heavier than I thought it would be.
J :seeya
Edit: I also did this with the belt in place.
[Modified by JCAIRE2, 5:13 PM 7/10/2002]
To Yet Another "Remove the Frisbee" Question
