REAR WHEEL HUBS
Old Jul 6, 2002 | 02:12 PM
bdtenore's Avatar
bdtenore
Default REAR WHEEL HUBS
In my search for a vibration that runs through the drive train, I noticed about a 1/16th to 1/8th inch of play on both of my rear wheels hubs when i place one hand on the top and one hand on the bottom and shake the wheel back and fourth. Is this play exceptable? I also checked my front wheels the same way and found no play at all. It seems like such a small amount to cause a vibration that you can feel in the seats. What do you guys think?
Old Jul 6, 2002 | 07:30 PM
bogus's Avatar
bogus
Default Re: REAR WHEEL HUBS (bdtenore)
That flex is not THAT bad...
however, a vibration could be tires, halfshafts or driveshaft....
I would also check the Ujoints....
Old Jul 6, 2002 | 08:17 PM
bdtenore's Avatar
bdtenore
Thanks for the reply. I should also add , I have balanced the wheels twice, changed the u-joints in the propeller shaft and had the shaft re-balanced, all of the the other u-joints are tight. checked the whole front end, its tight also. oh ya, Brand new tires.
To REAR WHEEL HUBS
