Volt meter moves with turn signal
Old Nov 2, 2013 | 11:33 AM
mxw128's Avatar
mxw128
Default Volt meter moves with turn signal
94 lt1
Anyone ever notice the voltage reading fluctuate when the turn signal is on? Seems somewhat normal at other times, but when the turn signal Flashes, the Volt reading fluctuates with the load.... I've seen it before on another late model C4... What would cause this?
Old Nov 3, 2013 | 02:04 AM
Cliff Harris's Avatar
Cliff Harris
When the lights flash they put a load on the system. That causes the voltmeter to dip.
This is especially noticeable at idle when the alternator isn't putting out much current. Usually you see it while stopped at a traffic signal with the turn signal on. If you rev the engine the variation will stop.
Old Nov 3, 2013 | 11:04 PM
mxw128's Avatar
mxw128
I agree that the added load is the cause, I just think that the alternator should be able to keep up, even at idle. Other vehicles that I've owned and serviced havn't done this, so I'm wondering if its something particular about the c4 that's an issue or if it it's an indicator of an alternator or battery that's under par. We used to be able to swap out the voltage regulators on alternators, but is that even a option on the newer ones?
Old Nov 4, 2013 | 12:17 AM
desertmike1's Avatar
desertmike1
Mine does this as well.. but the digital gauge is rock solid.
Old Nov 4, 2013 | 03:24 PM
don hall's Avatar
don hall
Originally Posted by mxw128
..... voltage reading fluctuates when the turn signal is on ......... What would cause this?
Faulty ground....
To Volt meter moves with turn signal
