Roller Rockers--Still Confused
Old Jul 7, 2002 | 12:31 AM
Irocan's Avatar
Irocan
Default Roller Rockers--Still Confused
I'm still a little confused on what exactly I would need to upgrade to 1.6's.
I have an '88 IROC L98 (iron heads). Do these have self aligning rockers in stock form?
What exactly would I need to upgrade to full rollers (other than the rockers and valve springs)? I will be replacing valve springs too but don't want to have to machine the heads to fit them.
Bob
Old Jul 7, 2002 | 10:46 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Roller Rockers--Still Confused (Irocan)
If your car doesn't have guide plates then it has self aligning rockers. You can use either, just remember that if you get normal rockers you HAVE to get guide plates, which will require hardened pushrods.
Other than that springs should just about do it.
Old Jul 7, 2002 | 10:59 AM
scorp508's Avatar
scorp508
Do yourself a favor and get non-self aligning rockers. They self-aligning ones eat up horsepower. It might cost you $50 more for some hardened pushrods and hardened guide plates, but it'll be worth it in the end. Even a set of new L98 springs SHOULD be ok with the added lift.
Old Jul 7, 2002 | 01:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Comp Cams now has 1.6:1 ProMagnum full roller rockers in either self-aligning or non self-aligning to fit 3/8" studs. If you want to install 7/16" studs only non self-aligning ProMagnums are available.
Your engine has non hardened guide plates (they don't contact the push rods) with self-aligning rockers.
Either use the self-aligning ProMagnums w/o guide plates or the non self-aligning with hardened guide plates and hardened push rods.
You should replace push rods in either case.
You can use the Comp Cams #981 single spring with damper to give a little more spring rate and it fits the stock seat. Use a shim pack to get the desired installed height and so seat pressure. If you toss the tin oil shedders from atop the stock springs to lighten the valve train you will also need the shims to achieve even stock installed height.
Get a set of OEM lower valve seals and upper O-ring seals from your Chevy dealer.
Use new valve retainers (keepers) to assure you don't drop a valve later. Comp Cams has machined retainers.
Old Jul 7, 2002 | 03:25 PM
thmupr's Avatar
thmupr
You might have to slot the pushrod holes to use 1.6 rockers. I am not sure, but some iron GM heads have a problem with the pushrod hitting the casting when using 1.6 rockers. Check with a local shop, or call Summit Racing, they're techs might be able to tell ya. :cheers:
Old Jul 7, 2002 | 04:13 PM
65Z01's Avatar
65Z01
Default Re: Roller Rockers--Still Confused (thmupr)
The #113 Al castings won't have to be slotted.
However a little surgery is required inside the valve covers:
1) reduce/remove the drip tabs
2) narrow the bolt posts.
Old Jul 7, 2002 | 05:42 PM
HighHopes85's Avatar
HighHopes85
Default Re: Roller Rockers--Still Confused (Nathan Plemons)
This is not true and is the source of MUCH confusion with cast iron heads. Been there...done that.
Cast iron heads in the early days used a "guide" that was machined into the head itself. It was a slot that would guide the pushrod. The factory setup with this style did not use self-aligning rocker arms.
Then Chevy started making some cast iron heads with a hole instead of a slot. These generally used guideplates and non-self aligning rockers.
When they came out with aluminum heads, they started using various combos of non-hardened guideplates and self-aligning rockers.
Good luck, -Matt-
Old Jul 7, 2002 | 09:23 PM
Nathan Plemons
Default Re: Roller Rockers--Still Confused (HighHopes85)
Ok, fair enough. Let me rephrase. In the LT1 world, if it doesn't have guide plates it has to have self aligning rockers.
:cheers:
Old Jul 7, 2002 | 10:35 PM
Irocan's Avatar
Irocan
I'm starting to get a clearer picture now.
What is the lift of the stock cam? Do you guys think this is a worthwhile mod? I have a superram base, AS&M LTR's and ported plenum as well. Edelbrock headers and Flowmaster exhaust.
I will not be able to get into heads and cam swap for quite a while (read a couple of years). I really need to get it painted this year.
If I can drop et's by a tenth or two I'd be happy for now.
Bob
Old Jul 10, 2002 | 09:27 PM
Irocan's Avatar
Irocan
Just asking again :D
Bob
To Roller Rockers--Still Confused
