Injector questions
Car seems to run fine, but the SLP runners were a tight fit on the #7 and #2 injectors, forcing me to remove the spring clips and cut back the injector plugs a bit to fit (barely). One of them (#7) ticks rather loudly. Seems to work ok (runner temp seems in the ballpark), but I'm reconsidering trying to install Bosch IIIs, this time 24lbs.
I'm assured by another vendor that their IIIs have a modified seat that stops any leaking. I'm looking at the blue 24lb set. I'd like to increase my capacity a bit for some better mid-high rpm capacity and some future headroom.
These are rated at though 43.5psi. My pump is 40psi. If that's linear, then the 24lb/hr rating drops to 22lb/hr.
Questions:
1. Any advice on leakage?
2. Should I go bigger than 24lb@43.5 to get headroom?
3. Recommendations on what injectors to use, and how to reprogram the tables for them? BTW I use modified $6E and run at 13.7 stoich (as low as I dared go with the narrow band o2).
The Bosch blue 280-155-715 flows just a bit more than 24, but installed at 40 would be a great fit for you. Why in the hell you changed your AFR to 13.7 I'll never understand. I rarely go under 14.5, and the ECM goes open loop under WOT which should be tuned to .860 or slightly higher on the O2. this will get you close to 12.5:1 AFR.
One thing I can't cure is the hot-air shroud the condenser makes. I've thought about fabbing brackets to hold a smaller (in LxW terms) condenser that lets some cool air get to the radiator. I could get away with that because my aux fan is triggered by the compressor clutch signal. But unless I get an 85F-plus day in November (not looking likely up here) I'll probably wait until summer to see if I even need it.
BTW, some of the things you find... after jumping through hoops to cool the oil, I noticed the other day that my dipstick shaft was pressed up against the AIR tube (which is not in use but sure gets hot). I moved it off a bit and voila, my oil temps around town seemed to drop a good 10* from what I'd been seeing even on cooler days.
