How old is your radiator cap?
Old Nov 9, 2013 | 04:54 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default How old is your radiator cap?
When was the last time you had it pressure tested?
Just something to think about when chasing problematic temperature issues.
Old Nov 9, 2013 | 06:26 PM
don hall's Avatar
don hall
Good reminder post..
Even a new gasket should be considered in regular maintenance.
FYI.... the new caps are designed for 'easy on' and 'easy off'.
Many new caps are made by Stant, and packaged under various brand names, including ACDelco.
According to Stant, all new caps are designed for both 'open' and 'closed' systems.
Old Nov 9, 2013 | 08:06 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I replace mine every 5 years. Ghost's is 3 years old, and Betty Boop's is 2 months old.
Old Nov 9, 2013 | 09:52 PM
l98tpi's Avatar
l98tpi
Max G’s
good point to mention.
Old Nov 9, 2013 | 09:58 PM
mmandley's Avatar
mmandley
I replace mine every year because i used to own a 6.0 diesel and this was a common fail item.
Now i just replace it every year in all my vechicles, simple $15 part.
Old Nov 10, 2013 | 12:32 AM
Cliff Harris's Avatar
Cliff Harris
What I have seen is that radiator caps lose their pressure rating and allow the radiator to boil over when the engine is turned off. You can hear a gurgling sound as the coolant boils into the overflow tank (assuming you have one -- later cars have a remote tank with cap on it).
Old Nov 10, 2013 | 06:35 PM
vader86's Avatar
vader86
I replace it every 3-5 years along with the battery.
Old Nov 10, 2013 | 11:32 PM
vetset84's Avatar
vetset84
i test mine every summer. thought i would upgrade to the stant racing one because i thought it is better than the standard one. WRONG. the stant racing looks good and cost three times as much, but fails 1 to 2 psi out of the box and after a few months it was 5 psi off. wrote to stant to find out why it failed so bad and their QA dept didn't catch it or what. never was responded to and questions remain unanswered. I have the best luck with ac delco and also change the thermostat at the same time. a good cap will hold pressure and cause other problems that you may not know of. in my case intake gasket and radiator started to leak. just saying if you don't have any overheating issues, changing an old cap may cause more indepth problems. currently i have the intake off because of this.
To How old is your radiator cap?
