Optispark to Coilpacks
Old Nov 19, 2013 | 01:39 PM
smooth1990's Avatar
smooth1990
Originally Posted by dizwiz24
Its cool you got it to work. I dont see any downsides either (to coil pack conversion) other than cost.
In fact, DVCNI pointed out that if you do go to an LSx computer swap, that you will need to convert to coil pack anyways.
However, I suspect the OP doesnt plan on going that route and simply believes the optispark to be 'not reliable' and the only thing that is going to make his car reliable is if he goes to a coil pack conversion.
This is so not true...
Okay.....why my attitude?
Ive been so strong-winded on these posts because:
Ive gotten tired of hearing about people swapping out the optispark for a $69 made-in-china optispark, or (worse) a $500 MSD still-piece-of-garbage-optispark, and then complaining that the optispark is an unreliable piece of junk.
this is not about some 17 yr old and his lt1 camaro, or 24" rim b-body. Any of those optisparks have no place in these machines.
Why did your stock one fail? Simple. if its a 92-94, its because it wasnt vented and/or the seals cracked allowing water intrusion (just as mine did with only 26000 miles on it). If its a 95-96, then something broke down in your vent harness and/or the seals broke. I coat my optispark seal edges in RTV silicone as an extra fail-safe.
Ive said it a million times. You must use an OEM new old stock optispark with mitsubishi optical sensor and add a vented harness if you have a 92-94.
Also, coat the edges of the optispark with rtv.
Totally understandable..
Old Nov 19, 2013 | 02:22 PM
DVNCI's Avatar
DVNCI
So you're the guy with the vortech YSI...
Not yet, but in a couple months I will buy one. I've already bought Greg's ATI damper kit and will be buying the bracket and supercharger from him as well.
I want to get the car up and running first on the eficonnection kit, then I will add the YSI.
There are a few other members with YSI's, I have their names written down somewhere . . . .
-sorry for the hijack
Old Nov 19, 2013 | 06:31 PM
RWC112's Avatar
RWC112
Default Mitsubishi Optical sensor
how do I tell if the distributor has a Mitsubishi optical sensor/pickup/trigger ? I bought a distributor that I thought was a AC delco and was informed it might be but it would depend on where it was shipped from blah blah blah so how do I tell if I have a good sensor for the distributer
Old Nov 19, 2013 | 09:01 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Originally Posted by DVNCI
I would expect a slight power increase but that's not why I'm doing it. I'm actually a fan of the Optispark (at least the original Dynaspark that actually I have for sale now). I have never seen a car start up faster than mine - it's almost instant.
I'm primarily doing it to get the LS computer - more specifically for boost. I will be adding a Vortech YSI soon and the LS computer has provisions for boost - LT does not.
Running boost with my LT1 reprogrammed stock computer, relies on the MAF to detect the added air and add fuel
Old Nov 19, 2013 | 09:19 PM
DVNCI's Avatar
DVNCI
I'm going MAF-less because I'm planning on making 800 hp or better, so that won't work for me. As you know you can't go past 1 bar w/ LT computer if running speed density.
I would think you are close to pegging your MAF right now?
I'm not saying you can't run boost with an LT1 computer, just that the LS computer is 10 times better for that because it "understands" it.
Old Nov 19, 2013 | 11:49 PM
smooth1990's Avatar
smooth1990
I have a 2 bar map on my 92 right now.
Old Nov 20, 2013 | 09:12 AM
RWC112's Avatar
RWC112
I have a intermittent miss and whial driving the Optispark seems to have some malfunction the engine vibrates and when I give it some gas the acceleration just liberates more then kicks in so I am looking at replacing the optispark sooner then later I have a new Water pump just need a distributor LT4 seal kit the water pump drive shaft was thinking might as well replace the timing set to extreme duty roller set and replace the lifters as I have a set and one is ticking now and then
Old Nov 20, 2013 | 09:30 AM
DVNCI's Avatar
DVNCI
You may have a 2 bar MAP sensor but how are you telling the PCM the car is actually seeing 2 bar? As far as I know, there is no way to have a MAP table in an LT computer go above 1 bar?
I'm guessing you are scaling everything in half - which I don't want to do.
Old Nov 20, 2013 | 10:11 AM
smooth1990's Avatar
smooth1990
You have to change the slope and offset of the map sensor then verify it's working with air pressure and a gauge. I did that before tuning. Then the maps have
to accommodate above 100kpa and need to be rescaled...that's all don't too up to 200 kpa.
Old Nov 20, 2013 | 10:12 AM
smooth1990's Avatar
smooth1990
Those are the words of my tuner. I dont tune the car myself. I have it done on a dyno..
Old Nov 20, 2013 | 10:18 AM
DVNCI's Avatar
DVNCI
Exactly - it's a bit complex because your PCM doesn't "understand" what's going on.
As I said, people can and do make it work just fine, but I like things simple and clean. Also, I do my own tuning, so I want it to be easy.
Old Nov 21, 2013 | 12:45 PM
dizwiz24's Avatar
dizwiz24
Here is a picture (i took) of the genuine mitsubishi optical sensor on a gen 1 (92-94) AC Delco optispark.
The 95-96 looks a little different, but does have a smaller mitsubishi symbol on the optical sensor.
