'90 C4 fuel injectors and ECM
Old Nov 13, 2013 | 04:25 PM
JJLovell's Avatar
JJLovell
Default '90 C4 fuel injectors and ECM
So, I've installed a Borla cat-back, SLP cold air induction, SLP runners and some hi-powered ignition goodies...At what point do I increase the injectors? I was told by a chevy tech dude that I could get away with up to a 31 lb. before needing ECM work done, does this sound right? I planned on maybe installing 28lb. injectors and a adjustable regulator, good idea or not? And incidently I installed the Spec stage 1 and their "heavy" billet steel flywheel, made the noisey tranny happy, and hooks real good....
Old Nov 13, 2013 | 05:13 PM
MrWillys's Avatar
MrWillys
Hogwash, that may be semi true for mass air cars, but not speed density. Your car is constantly adjusting fuel for a perfect 14.7 AFR. The factory memcal is programmed for a 22.1 lb injector. Adding 28 lb injectors would be beyond the ecm's capabilities to adjust fuel settings, and would run overly rich without reprogramming. Larger injectors are not needed until cam and compression, and head flow have been significantly increased.
Old Nov 13, 2013 | 06:11 PM
Klyde's Avatar
Klyde
So far you have listed nothing that would warrant upsizing the injectors. I agree you run the risk of going above what the ECM can handle. What I found is that the regular Fuel Pressure Regulators seem a little low on the pressure side and you can gain a little extra response by adding a adjustable regulator. I set mine for the highest recommended by GM and the car is a lot quicker with throttle changes.
Old Nov 13, 2013 | 11:14 PM
GKK's Avatar
GKK
Not!...
Larger fuel injectors will add Zero horsepower, for your basically stock engine.
To '90 C4 fuel injectors and ECM
