Rearview mirror shakes !!
Old Jul 7, 2002 | 09:39 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Rearview mirror shakes !!
My rearview mirror used to shake a lot, so I put some loc-tite on the screw, and tighted it up. No problem...until now. It's shaking again, and I cannot loosen/tighten the screw due to the loc-tite. AAAHHHHH!!!!! :mad
What to do?
Is there anyway to over-power loctite?
Old Jul 7, 2002 | 09:47 PM
GlockLT4's Avatar
GlockLT4
Default Re: Rearview mirror shakes !! (FlyboyZR1)
epoxy :D don't ever plan on taking it off though.
[Modified by Glock'94, 7:47 PM 7/7/2002]
Old Jul 7, 2002 | 09:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Either a larger allen wrench or a carbide drill.
Remove the mirror and examine the mounting surface. It may have a depression worn that needs to be filled in.
Old Jul 7, 2002 | 10:38 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Rearview mirror shakes !! (65Z01)
How do you remove the mirror? I can't remove that black screw on the bottom due to the loc-tite.
Old Jul 7, 2002 | 10:58 PM
Denney's Avatar
Denney
Loc-tite really should not have frozen the screw such that it won't come off. I would recommend trying again and maybe using a little more leverage. I have used loc-tite on many things and haven't run into any problems like frozen screws (although I will admit I have never used it on anything that had plastic around). Good luck!
Old Jul 7, 2002 | 11:05 PM
XtremeVette420's Avatar
XtremeVette420
Default Re: Rearview mirror shakes !! (Denney)
Yeah but it all depends on which loctite color he used. When I used to work at the local hoby shop we had different loctites for different jobs. On helicopters we used the one b/c of their vibrations and for the cars we used the lesser one. Can't remember which color is stronger or weaker though, hmmm. Good luck b/c I've frozen plenty of screws with that stuff, doesn't come out.
Old Jul 7, 2002 | 11:07 PM
GlockLT4's Avatar
GlockLT4
Default Re: Rearview mirror shakes !! (XtremeVette420)
I usually use Blue.
Old Jul 7, 2002 | 11:09 PM
FlyboyZR1's Avatar
FlyboyZR1
Well the stuff was in a little blue container, but the liquid itself is red.
Old Jul 8, 2002 | 12:44 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I usually turn down the power to the subwoofers... cures it everytime. :jester
Old Jul 8, 2002 | 02:33 AM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
The blue Loc-tite is for general jobs and does a great job. The red is for semi-permanent jobs and can be a PITA to undo. Your best bet "may" be to try an impact wrench with a screwdriver fitting. It is not so much the total force as the quick application of force that helps break the screw free. If you used red, you may still break the screw or threads. Be prepared to buy a heli-coil for the threads. Good luck.
To Rearview mirror shakes !!
