Intermittent Clunk
Old Nov 17, 2013 | 05:55 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Intermittent Clunk
(cross-posted from C4 General because I think I might get some good ideas in C4 Tech)
[1985, A4, very stock, 71k miles]
When I drive Lauren I sometimes (of course) hear a clunk. It'll get louder, than softer, go away, come back, etc. More data:
1) If you forced me to pick where the noise is coming from, I'd pick passenger's side front, but I'm not absolutely sure of that.
2) I hear it with the HVAC on or off.
3) I hear it more when I'm cruising or slowing down.
4) There's nothing obviously loose in the engine compartment.
5) The sound doesn't seem to be related to bumpy roads.
Thoughts?
Old Nov 17, 2013 | 08:05 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Ball joints
Thoughts?
Maybe its the ball joints. It's a bit of a job so I'd check them both. If there's play that could cause a clunk.
You didn't say whether it was a vert. They are not as stiff and have a X cross-brace underneath. If the bolts are not tight, body twist can cause a clunk when you step on the gas ... among other nastiness like bad tracking and alignment issues.
Thinking out loud here.
Old Nov 18, 2013 | 10:30 AM
GKK's Avatar
GKK
Loose, engine mounts?...
Old Nov 18, 2013 | 10:33 AM
NuckinFutz93's Avatar
NuckinFutz93
Could be the shock.
Old Nov 18, 2013 | 10:38 AM
hcbph's Avatar
hcbph
Default Clunk source
Another possiblity is the front swaybar or ends. Doesn't take much wear on them (on a van) to make noise and they aren't that expensive to replace the bushings.
Old Nov 18, 2013 | 10:48 AM
hemivett's Avatar
hemivett
Sounds like a bad/broken shock. It will make a bit of a knocking sound when you hit bumps. You never really said when it does it. You could always make a front end alignment appointment, and they will tell you every thing thats wrong before they'll align it. h
Old Nov 18, 2013 | 10:51 AM
84wuzmy1st's Avatar
84wuzmy1st
Could also be the brakes? Caliper not releasing all the way?
Old Nov 18, 2013 | 10:57 AM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Originally Posted by hemivett
Sounds like a bad/broken shock. It will make a bit of a knocking sound when you hit bumps. You never really said when it does it. You could always make a front end alignment appointment, and they will tell you every thing that's wrong before they'll align it.
Shocks are fairly new (20k miles or so), but I'll check - the sound happens whether or not I'm hitting a bump (I'll add that to the original post). I got an alignment earlier this year.
Old Nov 18, 2013 | 07:28 PM
3D-Aircrew's Avatar
3D-Aircrew
Default All good ideas and most easy to check.
Time to roll up the sleeves, get out your tools, put on the Mechanix gloves and start checking things out.
FSM in hand of course.
Old Nov 18, 2013 | 08:28 PM
84wuzmy1st's Avatar
84wuzmy1st
Does it tend to happen when slightly turning the wheel one direction or another?
Old Nov 19, 2013 | 04:20 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
This doesn't seem to make a difference.
To Intermittent Clunk
