Brake problem on 91
Old Jul 8, 2002 | 09:58 AM
JIMBO55's Avatar
JIMBO55
Default Brake problem on 91
my brakes just started to shutter when i step on them--it happens at any speed--is it pads???? jimbo :confused: :confused: :cry
Old Jul 8, 2002 | 01:19 PM
ittlfly's Avatar
ittlfly
Default Re: Brake problem on 91 (JIMBO55)
Have you had work done recently on the car? If so, they may have reinstalled the lugs with an air gun. In that case, your rotors maybe warpping due to improper torque. If not, then it could be worn pads, guide pins etc. Is it in the front or rear of the car?
Old Jul 8, 2002 | 02:58 PM
JIMBO55's Avatar
JIMBO55
Default Re: Brake problem on 91 (ittlfly)
ittlfly---------it feels like all for wheels--no work has been done jimbo :nonod: :cry
Old Jul 8, 2002 | 04:22 PM
ittlfly's Avatar
ittlfly
It's unusual that all 4 would go out at once all of a sudden. Try this, run it up to a slow speed , say 15-20 mph. Apply your emergency brake WITHOUT usuing your foot brake. That will use only the rear brakes to stop you. See if the problem is heard / felt. If not, then it's in the frot end.
To Brake problem on 91
