89 Corvette alternator
Old Jul 8, 2002 | 03:17 PM
Pollock's Avatar
Pollock
Default 89 Corvette alternator
Mine went out. Is it worth it to get it rebuilt? I want to keep the car as original as possible. :hat
Old Jul 8, 2002 | 03:38 PM
pascualjr's Avatar
pascualjr
Default Re: 89 Corvette alternator (Pollock)
Check out the link below; there's a section on rebuilding the alternator yourself.
http://www.batee.com/corvette/index.shtml
:seeya
Old Jul 8, 2002 | 03:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I recently had to replace mine. I got a rebuilt AC Delso from a local vendor.
I read an article on rebuilding older alternators but said the our's are more difficult to do.
Old Jul 8, 2002 | 03:56 PM
Flame Red's Avatar
Flame Red
If you only want to replace it once, use http://www.powermastermotorsports.com/.
Or if you perfer replace it often, go the rebuilt route.
Old Jul 8, 2002 | 04:31 PM
Scoob's Avatar
Scoob
Odds are that an '89 won't be worth much down the road even if it is all original. But if that is your concern just save the original one for "later" and get yourself a new one. First timers can replace them in about 45 minutes. When you get a few under your belt you can do it in about 20.
Old Jul 8, 2002 | 05:12 PM
pablocruise's Avatar
pablocruise
Default Re: 89 Corvette alternator (Scoob)
And you will get a few under your belt. :D
I think I'm on #5 by now or something like that.
Observation: The one that is on now is an original AC Delco alt. It has been the one that has lasted the longest. Like 4 years.
All the other short lived ones were like from autozone and places like that.
Food for thought.
[Modified by 89 Paul in Cal, 1:13 PM 7/8/2002]
Old Jul 8, 2002 | 05:25 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I think is is far better to get YOUR alternator rebuilt then to buy a junk rebuilt from a auto-parts-chain. A good rebuilder will give you an alternator that is as good as or better than new.
I like marine rebuilders, find one with a good reputation.
Old Jul 8, 2002 | 05:37 PM
CptMorgan's Avatar
CptMorgan
Default Re: 89 Corvette alternator (PeteL)
Take your alternator to a good Auto electric shop. A good place will charge you $30-40 to rebuilt it and will put in heavier duty bearings and diods. The place I go takes cash and will rebuild it while you wait.
Old Jul 8, 2002 | 05:58 PM
Pollock's Avatar
Pollock
You obviously have no clue. :bs
[Modified by Pollock, 1:58 PM 7/8/2002]
[Modified by Pollock, 2:04 PM 7/8/2002]
Old Jul 8, 2002 | 07:52 PM
ZELLSLIFE's Avatar
ZELLSLIFE
Is it true that the 95 alternator can not be rebuilt?
Old Jul 10, 2002 | 02:38 AM
pfast89's Avatar
pfast89
Default Re: 89 Corvette alternator (Flame Red)
Should it be replaced with the high-amp one and how much $ are they?
Old Jul 13, 2002 | 04:44 PM
ZELLSLIFE's Avatar
ZELLSLIFE
Default Re: 89 Corvette alternator (pfast89)
I just replaced mine yesterday on my 95. I got a AC Delco with lifetime guarantee from advance auto 140 bucks with a $55 core charge I has 140 amps the old one had 124 amps. headlights are brighter and the extra amperage is much better for my stereo components. The only installation difference was the stud on the battery conection is bigger on the 140 amp alternator I used a 5/16 lock nut.
[Modified by ZELLSLIFE, 3:44 PM 7/13/2002]
To 89 Corvette alternator
