MSD 6201 electric ignition install question
I've got the box on the right front floor board in front of the speaker mounted vertical. It's grounded to the factory ground right above the speaker in front of the door.
The box turns on with the key in the on position, and when cranking the box flashes, but there seems as if there is no spark at all.
The car will not start with the MSD system... But just to check I did hook up the factory connectors back up to the coil and the car fired right up.
Any ideas on what I'm doing wrong here? The only reason I'm running this system is for the nitrous I plan on running in the spring.
