Help! At my wits end...
Old Dec 2, 2013 | 07:54 PM
Giamanut's Avatar
Giamanut
Man the new vettes are pretty excellent!
Old Dec 2, 2013 | 08:49 PM
TorchTarga94's Avatar
TorchTarga94
Purchased a fuel pressure gauge today.
With the key on / engine off I am getting a reading of 41 PSI
With the engine idling I am getting a reading of 43 PSI
Both of those readings are with the vacuum line to the fuel pressure regulator unhooked.
With the FPR vacuum line hooked up and idling I am getting a reading of 36 PSI.
This was cold so I still need to do a warm test but I think its safe to say that fuel pressure most likely isn't a problem. The pressure also did not bleed off at all really once the car was turned off. It maybe took 5 minutes for it to drop a pound.
Old Dec 3, 2013 | 06:35 PM
Giamanut's Avatar
Giamanut
I still think I would get it warm so it fails then Ice the IAT and Coolant temp sensors one at a time and see if it starts. At least you would eliminate them as a cause.
Old Dec 3, 2013 | 07:14 PM
TorchTarga94
I'll do that. I've heard you can use a keyboard co2 spray duster and hold it upside down and freeze test components. -109 degrees Fahrenheit and cheap.
Old Dec 3, 2013 | 07:25 PM
hooked073's Avatar
hooked073
were these fuel pressure reading when the car would not start? they mean nothing unless the car will not start. these fule pumps love to crap out when hot and shut off then after the cool for a while they work fine
Old Dec 3, 2013 | 08:09 PM
TorchTarga94
I won't really have the time to do a proper warm test until the weekend, but I will make sure to do that. Can the fuel pump really get that warm? Its at the rear of the car away from anything really hot.
Old Dec 3, 2013 | 08:34 PM
Giamanut's Avatar
Giamanut
Yes it can get warm if it is drawing lots of amps but I think the car would just die and not have the warm start problem. I am way more incline to believe electrical. I could be wrong about a sensor but it just my way of looking at it.
Old Dec 7, 2013 | 12:55 PM
rick lambert's Avatar
rick lambert
I'm betting against the fuel pump. One thing I'd do is take the new ICM back where I bought it and have them test it...make sure they run it through at least ten cycles though...most guys think 4-5 cycles is enough, but their mistaken.
I can't really say this about your 94, because mines an 87 l98, but one of the tell tale signs of a ECM going bad is similar...they shut down because there getting (the ECM) hot frequently, unfortunately we can't really test an ECM, neither can a parts house. But I think some of the guys on the forum in the past used something to keep it cool for test purposes. Hopefully someone will chime in.
Old Dec 8, 2013 | 09:33 PM
TorchTarga94
Thanks everyone for all of the input. After no luck testing various sensors and fuel pressure, it seems it was the Optispark. This time I went with a new Delphi unit, loctited the rotor screws, and sealed the cap with black RTV. Have not been able to replicate the issue I was having.
Old Dec 8, 2013 | 09:34 PM
TorchTarga94
I greatly appreciate everyone's help, not sure if I could get by without the helpful folks on this forum!
Old Dec 9, 2013 | 06:12 AM
Giamanut's Avatar
Giamanut
congrats on the find.
Old Dec 9, 2013 | 12:54 PM
LannyL81's Avatar
LannyL81
Hopefully it was the OptiSpark, but I would not be surprised to read that the problem reappears.
This sounds more like a PCM failing when hot, possibly the ICM or the ignition coil.
Time will tell......
Old Dec 9, 2013 | 07:32 PM
  #33
TorchTarga94
Gee thanks for the kind words of encouragement!
I kid. I wouldn't be surprised either, this car does whatever it wants. I really did my best trying to diagnose it but I can really only do so much with an intermittent problem like this. Used freeze spray on a bunch of sensors to try and isolate what the problem was. Sometimes it would fire up even after driving the car very hard for 10 to 15 minutes at a time. I don't know I have been having this problem ever since I changed the optispark with a cheap cardone unit from Advanced. The thing is is sometimes it would only does it once a month.
As you said, only time will tell. And so will my patience, it sucks trying to diagnose electrical problems and work on the car more than I get to drive it. I really don't even drive it hard for fear of breaking something else which really takes the fun out of it. I don't drive it a lot though, or try to. I'd just like it to be somewhat reliable. I understand it's an older car but this ignition system was a horrible, Horrible design.
Old Dec 9, 2013 | 10:02 PM
  #34
eatmydst1234's Avatar
eatmydst1234
i was using a new cardone opti on my car. the first one lasted the longest at just over 2000 miles. after the second one failed at 500 miles my store wouldn't give me my money back, however they gave me a full refund in store credit. Interestingly enough you can get the MSD vented cap conversion and a MSD coil for almost the cost of hat cardone opti, so i used my store credit to get that for my '93. i found a NOS GM opti for my car. I'm curious though, does the Delphi opti for the earlier cars have a Mitsubishi sensor?
Old Dec 9, 2013 | 10:09 PM
  #35
Giamanut's Avatar
Giamanut
Drive it like you stole it! have fun with it. It is designed to be driven. I drive mind like the sports car it is. they do require some tinkering but I look at it as part of the experience.
I have worked a lot on mine, but now I just drive it. There is an alternate ignition out there LTCC. Question for you , If I may.
Have you taken that cardone opti apart? just curious see if there is something blatantly wrong with it.
Old Dec 9, 2013 | 10:22 PM
  #36
eatmydst1234
i took apart both of mine, the both looked new inside. as would be expected after 2000 miles on the first and 500 on the second.
Old Dec 9, 2013 | 11:57 PM
  #37
Giamanut's Avatar
Giamanut
Thanks for the info I was just wondering why the opti thing is such a PITA. I think when mine gives out I'll do the ltcc think and be over it.
To Help! At my wits end...
Old Dec 10, 2013 | 05:28 AM
  #38
TorchTarga94
Giamanut- no I haven't taken the cardone apart. It has a lifetime warranty so I am going to try and return it for a refund since it looks like it crapped out after only 6 months. The one thing about the LTCC conversion is you still have to leave the opti hooked up to send a signal to the PCM. So you don't completely eliminate it. You do eliminate the distributor part of it though.
Eatmydst - What symptoms were you experiencing with your cardone units? Interesting you went through 2 of them, something must not be right inside of them. I am not 100% sure if the Delphi unit I installed uses a Mitsu sensor. I didn't delve that far into it. I do know Delphi built the opti for AC Delco during production. AC Delco just slapped their own part number on it. I have heard the Delphi units still use the Mitsu sensor but that doesn't confirm anything. It definitely seemed better built than the Cardone. Even the splines on the drive shaft looks better.
Old Dec 10, 2013 | 08:27 AM
  #39
eatmydst1234
The both of the cardone opti's failed in the same way. After car got to temp it would be running fine, then out of no where the temps would climb abnormally fast, we're talking from 193-225 in a matter of minutes, even with the cooling fans on high. When it hit 225 the tach would start dancing around and the car, would start shut down. Wouldn't start again until car cold down. Did all the test and failure was in the optical side of the opti. The only thing I can figure was that it wasn't controlling timing correctly which caused car to hear up fast. Now with the GM opti the car, is back to normal.
Old Dec 10, 2013 | 09:37 AM
  #40
TorchTarga94
That's interesting, sounds very similar. I have a feeling my cardone opti had a heat soak problem once the car was turned off. Had a hard time refiring. Hopefully this is my fix. I think I will space the ICM away from the head with some washers just to be safe. Wonder if there is also a way to help prevent heat soak on the PCM. I see it has cooling fins on the top to dissipate heat, wonder if I could put some heat wrap on the bottom side of it.
