rpm
Old Jul 9, 2002 | 01:20 AM
imaruby's Avatar
imaruby
Default rpm
Is it possible to get the engine rpm using the ALDL diagnostic connector?
Trying to set idle with a new throttle body.
Old Jul 9, 2002 | 01:30 AM
BobMachus's Avatar
BobMachus
Default Re: rpm (imaruby)
With the right cable and software yes, but it will read the same as your dash tach.
Old Jul 9, 2002 | 03:04 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The base idle on an L98 is 450 rpm and is nearly at stall. I feel I can estimate closely enough with a scan tool on the ALDL.
To rpm
