grease for bushings
Old Jul 9, 2002 | 10:52 AM
93 ragtop's Avatar
93 ragtop
Default grease for bushings
Generally speaking, should rubber bushings be installed dry or should some grease be applied? If so, what kind?
Old Jul 9, 2002 | 11:01 AM
BobMachus's Avatar
BobMachus
Default Re: grease for bushings (Red 86 4+3)
I always grease 'em up. I use Mobil 1 synthetic grease or a VERY nasty super-waterproof marine grease I got to do my poly bushing kit. Very few moving parts get upset when lubricated.
Old Jul 9, 2002 | 03:43 PM
93 ragtop's Avatar
93 ragtop
Default Re: grease for bushings (BobMachus)
Bob,
Thanks for your reply. I just didnt know if it was ok to grease the rubber bushings, such as the sway bar bushings etc, where the rubber actually touches the metal. I was concerned that it would deterioate the rubber. But I dont want squeaks neither. I knew the grease was recomnended for the poly bushings, again just wasnt for sure on the rubber. But tonight its going to get greased!!
Old Jul 9, 2002 | 05:09 PM
JasonL's Avatar
JasonL
I've used various greases on both poly and rubber; they all worked fine.
To grease for bushings
