Fan Motor not getting volts
Old Jul 9, 2002 | 12:16 PM
97Supra's Avatar
97Supra
Default Fan Motor not getting volts
I've posted about this earlier and still can't find the problem. My hvac fan motor is not getting any voltage. I've replaced the relay, tested the fan (it works w/12 v applied), etc. but I can't figure out why, when I turn the a/c on, no voltage goes to the fan motor. I've traced the wires as far as possible and they look fine. Does anyone know if there is a switch, fuse, or another relay that might cause this problem? All the fuses in the main fuse block are fine, and I can't find another fuse that might control the fan. Any help would be appreciated!
Thanks,
Jason
Old Jul 9, 2002 | 04:18 PM
jfb's Avatar
jfb
Default Re: Fan Motor not getting volts (97Supra)
Follow the large red wire from the fan relay to the battery, it has a fusible link on it and it may be open. Also check the wiring harness at the fan for a continuous ground.
Old Jul 9, 2002 | 06:25 PM
97Supra's Avatar
97Supra
Default Re: Fan Motor not getting volts (jfb)
THanks...I tried that, but the wire is bundled with so many others it was difficult. I'll have to tear into it tonight and try again.
Jason
To Fan Motor not getting volts
