Weird Mirror toggle issue
Old Dec 9, 2013 | 02:20 PM
ccollet's Avatar
ccollet
Cruising
Default Weird Mirror toggle issue
I was wondering if anyone else has seen this, i was going to get a new toggle switch, but then figured that it can't possibly be the switch.
the toggle switch will control up and down on the passenger mirror, but the horizontal does nothing.
when i switch to the drivers side mirror the toggle works the driver mirror horizontally, but does nothing up and down.
Old Dec 9, 2013 | 02:45 PM
leesvet's Avatar
leesvet
well........
its worth trying a couple things before pulling the wallet out..
I would simply jiggle the glass on both mirrors and see if the motors may be stuck. These are really very simple in operation. There is a flat drive motor "pak" that has 2 threaded screw ports...an X axis and there is a Y axis.
The glass has 2 threaded studs at 12;00 and 3;00 (approx) that fit into the motor drive pak holes. When you want to tilt up the hole that's at 12:00 will run forward or rev to pull in or out the stud that's being engaged in that screw hole port. This tilts the glass up or down as desired. Works the same for the L/R axis. The joy stick CAN engage X & Y axis together. So up & rt is possible together.
These motors are sealed pretty good BUT the threads on the studs can collect some dirt and crud over the years and cause the motor screw drive to bind and not operate. Often a gentle bump will dislodge the dirt on the threads and allow it to turn again. If you can get someone to use the button as you try to wiggle the glass, that may help too. These studs and screw drives are NYLON...so you can force it to slip thru and manually set the mirror. I wouldn't do that too many times because it will eventually strip out the threads...
If that has no effect then you have to go in the console to get to the switch and the harness....I doubt the problem is there since you have already proven the switch itself is functional. More likely an actuator problem, not a control issue.
Good luck !
Old Dec 9, 2013 | 04:08 PM
JackDidley's Avatar
JackDidley
Mine go up, left and right. No down. I think its the switch but dont care enough to make a project of it.
To Weird Mirror toggle issue
