Do I need a bigger throttle body?
Old Dec 11, 2013 | 09:41 AM
volkswagens-for-life's Avatar
Default Do I need a bigger throttle body?
Mods are in signature. Is my build something that would improve by using a larger throttle body?
Old Dec 11, 2013 | 10:12 AM
vader86's Avatar
vader86
Ported TPI intake/plenum? No aftermarket runners or manifold?
Old Dec 11, 2013 | 10:15 AM
No, stock runners and manifold for now. Would like to upgrade in the future though, but no solid plans as of yet.
Old Dec 11, 2013 | 10:44 AM
John A. Marker's Avatar
John A. Marker
Your stock 48mm TB is good up to about 400 HP. I don't see the motor putting that out with stock intake, runners and plenum.
You could go to the 52mm TB without any impact to the tune.
Old Dec 11, 2013 | 10:51 AM
Its getting dyno tuned this summer... dont much care about the current tune. So that should have no bearing on your guys recommendations.
Old Dec 11, 2013 | 11:14 AM
cumbercr's Avatar
cumbercr
You won't get any more power from a throttle body. The intake and runners are your bottle neck.
Old Dec 11, 2013 | 01:37 PM
93 ragtop's Avatar
93 ragtop
even your 22lb injectors will run out of fuel before the 48mm will not flow enough air. 2 things FWIW. 1. When I was making 362rwhp 3000 stall etc. I switched from a 48 to a 52 and could not see any difference at the track. 2. The 502-502hp bigblock used a 48mm.
Old Dec 11, 2013 | 02:09 PM
^Interesting.. I know track results are much more important than dyno results, but did you redyno the car after the 52mm tb?
Old Dec 11, 2013 | 02:14 PM
John A. Marker
as written above....the TB will not give you HP. It is a air inlet only. Change the runners and plenum to get additional HP.
You computer will compensate for any difference between a 48, 52 and 58 TB. Your better staying with the 48 with your current combination or only moving up to the 52 not the 58.
Old Dec 11, 2013 | 02:20 PM
Hey John, out of curiosity what kinda dyno #'s did your old '85 put down to run that 13.2?
Old Dec 11, 2013 | 03:07 PM
Churchkey's Avatar
Churchkey
48mm throttle body flows 783CFM. If its an early TPI the choke point is the MAF,
http://gmtuners.com/flow/
Old Dec 11, 2013 | 03:10 PM
Is an '87 considered early tpi?
What kind of gains are associated w/ upgrading my maf, and where are some good brands to start looking?
Old Dec 11, 2013 | 03:34 PM
John A. Marker
It depends on which dyno. I had one say that there was 350 HP at the engine and 430 pounds of torque. Another 265 HP and 320 torque.
Old Dec 11, 2013 | 03:37 PM
93 ragtop's Avatar
93 ragtop
[QUOTE=volkswagens-for-life;1585650493]^Interesting.. I know track results are much more important than dyno results, but did you redyno the car after the 52mm tb?[/QUOTE]
No
Old Dec 11, 2013 | 03:55 PM
vader86's Avatar
vader86
I dont understand the question about early TPI, theres relatively little difference between the years.
You do not need a bigger TB or an upgraded MAF.
Old Dec 11, 2013 | 03:56 PM
Oh
Old Dec 11, 2013 | 05:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
we all wanna think our motors need larger stuff when in fact most the time they dont. Save your $
To Do I need a bigger throttle body?
Old Dec 11, 2013 | 05:31 PM
works for me, lol
Old Dec 11, 2013 | 06:01 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'd put a differential pressure gauge across the throttle body to measure the actual restriction (ie: pressure drop). Takes the guesswork out of it.
Old Dec 11, 2013 | 10:41 PM
Churchkey's Avatar
Churchkey
85 thru 89 = MAF
90 & 91 = speed density, no MAF
Agree with Vader, you don't need bigger TB or MAF until the stock intake, heads, cam & exhaust are changed, Only then can the engine breath past 5K rpm.
