Low idle when cold?
Mini ram, longtube headers, flat tappet zz409 cam, all free mods, k&n air filter, msd 8.5mm ignition wires, 58mm throttle body, stock heads.
Anyways, when I first turn it on, it is kind of weird. It idles at around 500-600 RPMs. After it warms up and goes into closed loop it idles at 700-750 ish.
The car has a tune and the AFR guage reads rich around 12-13:1 when it is cold, as it warms up and the idle increases, it reads around 14.7:1.
Has anybody ever experienced a problem like this? If I remember correctly, the idle while cold used to be around 700-750.
Thanks.
Thanks.
I guess that its possible that it could just be what the computer wants it to do but, it may not be functioning?
I'm going to investigate it a little more when I get home.
This is the CTS on the front of the intake manifold under the throttle body.
If the ECM thinks the coolant is cold it will raise the idle. If it thinks the coolant is hot (which appears to be your case) it will lower the idle. The best way to find out is with a scanner, either standalone or laptop software.
