From: Are you the bug or are you the windshield.....
Increase water flow at idle question.....
What is a good way to increase the amount of water flow through the engine while the car is at idle while stopped in traffic?????
The temps for the engine are fine during driving conditions, but while stopped at a light the temp just climbs, and I'm thinking if there is a way to get more flow through the motor it would stay cooler.......
The fan cools it off, but I'm looking for something that will help when the AC is running, and the fan is on constantly......
Re: Increase water flow at idle question..... (Husker Vette)
If you are stopped in traffic and your fans aren't on...there will be no air going past the radiator...hence the reason you car get hot (and all other C4's). Older cars had engine driven fans that turned all the time...
Adding a high flow waterpump will help to a point (how much?) but you will still be in same boat. The engine will get warm when parked...not overheat, just hot like it was designed.
Two months ago I had a head gasket fail in my 87 vette and did a lot of work on the engine as it had 177k miles on it and I didn't want to go back in it later. The water pump was just starting a slow leak at the weep hole so I replaced it with a Stewart , $104 delivered, because of its higher coolant flow (41% by their ads). With 90's temps and sitting at a light and with the stock 195 thermostat, I use my manual switch to force the fan on and the coolant temp goes to 200 F and drops to 195 when I get underway. With the GM pump, same conditions, my coolant temps went to 220 F and would slowly drop when I got underway. I knew I needed more coolant flow when I had the GM pump because I could lower the temperature at a stop light by racing the engine , proving that the GM pump flow is inadequite at idle. I highly recommend installing a Stewart water pump. After all the engine work, I watched as my mechanic left my 87 idle and the temp went to 238 F , the fan came on and the coolant temp dropped to 211 F and the fan shut off and it would repeat this cycle.
Re: Increase water flow at idle question..... (jfb)
This is what I was wondering, because while driving with the AC on (which means the radiator fan is running also) my temps will shoot up while sitting at a light, but once I start to increase the rpm's of the car, the temp begins to fall.........
When the AC is not running, it follows the normal path of up to 227, fans kick on, down to 212, fans off but it seems to want to run up high while the AC is running and wont drop until the RPM's are increased....
Hopefully I can get through the summer, and I can make this a fall project when it is cooler outside.....
Re: Increase water flow at idle question..... (corvette0096)
Not saying anything bad about Stewart, but being as I am a cheap skate....I think the only real benefit of a stewart pump is this:
Stewart High Flow impeller offers a closed back machine iron installed with .015" clearance for greater flow and pressure
Of course, that impeller back plate was only $10.00 last time I bought one from Summit.
I'm not too worried about the quality of a GM pump...heck the one on my 87 has been there for 117K miles and still works fine, so I don't think I need better bearings or anything.
