84 corvette 02 sensor help needed
Old Dec 23, 2013 | 12:20 AM
phucking-low's Avatar
phucking-low
Default 84 corvette 02 sensor help needed
After talking with some people I am in need of a heated 02 sensor for my 84 corvette because I am running headman headers and the 02 sensor is located down in the collector. I want to make sure I am getting the correct sensor and someone told me a 93 zr1 02 sensor is heated and will work. Here are two sensors that came up on advance auto web site looking under a 93 zr1, which one do I need and also how do I wire this up going from 1 wire to 3 wire it looks like there is one black wire and two white wires.
http://shop.advanceautoparts.com/web...932%7CL2*16465
Old Dec 23, 2013 | 07:44 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Here is a link to a kit for a heated O2.
http://www.casperselectronics.com/st...roducts_id=698
Old Dec 23, 2013 | 07:49 AM
jadedvette's Avatar
jadedvette
Any three wire O2 sensor will work. One wire is ground, one wire goes to the computer. And one wire is 12 volts for the heater. It's common to do this on cars with one wire O2 sensors when adding long tube headers. Good luck, Joe
To 84 corvette 02 sensor help needed
