time to pull the engine?
Old Jul 10, 2002 | 02:58 PM
torque91's Avatar
torque91
Default time to pull the engine?
After 190,000 miles I think it might be time. I went to start the engine today and "thud". The starter worked but the engine wouldn't turn as if I had a seized alternator bearing. I loosened the drive belt and check all of the pullies. They were all ok. I tried to start it again and, low and behold, it started. I backed out of the garage and hopped out of the car to get something out of the truck. As I walked around the back of the car, I noticed smoke coming from both tailpipes. Could this be a bad cylinder ring? I would say that after 190,000 un-rebuilt miles, the rings are probably a bit tired. Any help would be greatly appreciated.
Old Jul 10, 2002 | 03:43 PM
Rick86's Avatar
Rick86
Default Re: time to pull the engine? (torque91)
You need to do a compression test or leak down test to determine if its rings or valves, but I'd say you already got your monies worth out of that engine.
Old Jul 10, 2002 | 04:40 PM
ToddAT's Avatar
ToddAT
Might be a head gasket or cumbustion chamber coolant leak. If the engine was not turning over, one of the cylinders might have had water built up in it, preventing it from turning over. Then, if you let it set for a few minutes, enough water will leak out to allow the engine to turn over and start. The smoke that you are seeing could be steam.
I've seen head gasket failures act this way, plus I had a pinhole in one of the combustion chambers on my '86 'vette do the exact same thing.
Old Jul 11, 2002 | 01:46 AM
Corvette0096's Avatar
Corvette0096
Default Re: time to pull the engine? (ToddAT)
Old Jul 11, 2002 | 11:58 AM
torque91's Avatar
torque91
Thanks guys(2 of you anyway). I am colorblind so it makes diagnosing smoke and fluid leak sources a bit hard. I started up the car again after I got home yesterday and it took a while for the smoke to start again. I checked the dipstick and there is no sign of coolant in the oil. I replaced the head gaskets about 60,000 miles ago. It might be time to take a look at them again. Oh well, that’s a good excuse to get some head work done while I’m at it.
To time to pull the engine?
