2014 autox setup (advice wanted)
Old Dec 28, 2013 | 10:52 PM
lozer's Avatar
lozer
Default 2014 autox setup (advice wanted)
For the 2013 year i came in second overall with 4 wins out of the 5 i ran with this car. (89 vert with super ram 383)
2013 setup was ( this pushed just a little at the limit)
Spring
F 115.5
R 87.5 (The jacking was addressed by keeping spare tire and minimizing rear ride height to be +1/4" higher then the front)
Sway
F 26t
R 22S
Purposed 2014 setup
Springs
F 115.5
R 57.2
Sway
F 32S
R 26S (ride height will be 1/2" greater then front)
Alignment for both years will be
F -2.5 Camber +3/16 Toe out
R -1.5 Camber 1/16 toe in
With this setup i can ditch the extra weight from the spare and assembly. I am also striping the interior and removing the headlight assembly's, a/c setup and audio, ect..
I guess i'm wondering if i'm being a jackass by going from what was clearly a working setup for me and trying to improve.
Old Dec 28, 2013 | 11:56 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
You will notice a big diff with those bars, I did.
Old Dec 29, 2013 | 03:50 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I'm running -2.0 camber in the rear, might crank it up a little more.
What's your tire/rim size?
Old Dec 29, 2013 | 04:01 PM
l98tpi's Avatar
l98tpi
Max G’s
Question, are these changes going to change your class? What were your times compared to top time of day, considering cars not carts. Do you run race compound rubber or street rubber?
Old Dec 29, 2013 | 08:32 PM
lozer's Avatar
lozer
I would run more neg camber in the rear but at the height im at the camber is maxed @ -1.5
Im running 17x9.5 on all 4 corners with star spec II @ 255x40 r17
im trying to find another set of wagon wheels so I can run 18x9.5 with 295s
Ill be in the same class as my club is really relaxed.
I was regularly in the top 10 and got ttod on street tires twice
The more I think about it the less I want to change it
Old Dec 30, 2013 | 01:56 PM
BrianCunningham
Need to get some 275's on those rims
255's are definitely holding you back
Old Dec 30, 2013 | 08:25 PM
lozer's Avatar
lozer
I agree but trying to find a 17" 275 that's as competitive as the star spec is impossible.
SO im hunting down 2 more 18" wagon wheels and im going to run 4 18x9.5 wagon wheels with the new bfg rivals. I still have some life in the Star specs so this will be a mid season tire change.
http://www.tirerack.com/tires/tires....8GFR&tab=Specs
Old Dec 30, 2013 | 10:22 PM
93Rubie's Avatar
93Rubie
Unless your going to run R-comps, good rubber in 275/40/17 does not exist for auto-x. The best three tires the ZII, Rival, and RS3's only come in 255/40/17. You'll need to go to 18's as you noted. I'm in the same boat, however, I'll have to wait till 2015 for the change to 18's. That will give me and my wallet a better feel for how the new rule changes are going to effect things.
Old Dec 30, 2013 | 10:37 PM
l98tpi's Avatar
l98tpi
Max G’s
Don't change the suspension set up, just get better tires.
here is a better tire in the 275/35/17
http://www.tirerack.com/tires/tires....omCompare1=yes
Old Dec 31, 2013 | 12:06 AM
lozer's Avatar
lozer
the toyos would be awesome but they would throw me into race tire class. (120 min tread wear)
I know i'm really on the fence about changing up the bars and rear spring.
Old Dec 31, 2013 | 01:28 PM
Race Prepared's Avatar
Race Prepared
https://www.hoosiertire.com/rrtire.htm A-6 Hoosier in 275/40/17?
Old Dec 31, 2013 | 02:09 PM
lozer's Avatar
lozer
The a6 is also an R compound so its a no go for either of us.
Old Jan 1, 2014 | 08:10 PM
lozer's Avatar
lozer
All this chating about tires is nice but im still wondering if any of you winning autoxers think i should stay with the stock sways and 84 rear spring or go big sways and 57nm spring?
Old Jan 1, 2014 | 08:15 PM
93Rubie's Avatar
93Rubie
Ok, first off, what rule set are you operating under? Also, you want street tires or R-comps? I'm guessing street tires.
I'd do your 2014 proposal as presented by you. That 84 Z51 spring is just too stiff as you noted, jacking. Its fairly well documented that the 89 Z51 cars are probably the best handling 17" tired C4's. They are the ones that have WON at SCCA Nationals in Stock class, most recent being in 2009 and 2006.
Old Jan 1, 2014 | 10:58 PM
lozer's Avatar
lozer
Basically its wide open with the exception of tires. and yup im running street tires.
Thanks Rubie, that's what i was thinking also. Now should i go with the massive sway bars also or stick with the tiny stock bars.
Old Jan 3, 2014 | 10:28 PM
93Rubie's Avatar
93Rubie
Big bars.
The good winning street tires for auto-x are pretty much the BFG Rivals, Dunlap Dizzera ZII's, Hankook RS3's, and the some Toyo R1R's. I'd stick with the Rivals or ZII's.
Old Jan 5, 2014 | 01:44 PM
BrianCunningham
The street tire drivers here are running the 32mm bar up front.
To 2014 autox setup (advice wanted)
Old Jan 9, 2014 | 10:57 PM
IBVETN2's Avatar
IBVETN2
Will the 89 Z51 front spring fit in an 86?
Old Jan 10, 2014 | 07:30 AM
HandsomeMike's Avatar
HandsomeMike
I don't believe the front spring from a 88+ will fit in a 84-87 due to a different front suspension design. Same with front sway bar. The rear springs and sway bars from 84-96 are all interchangeable.
Old Jan 10, 2014 | 04:37 PM
Crepitus's Avatar
Crepitus
I think the late front spring will fit an early car if you use a late spring clamp
http://www.vansteel.com/index.cfm?fu...p=1950&ID=3162
