C5-C6 wheels on 84 C4
Old Dec 31, 2013 | 05:01 PM
Apache 84's Avatar
Apache 84
Default C5-C6 wheels on 84 C4
Hi Guys,Can anybody put point me in the right direction regarding C5-C6 wheels as to,will they fit under my 84 Corvette.
I would like to purchase some C5 wheels ,but unsure if they will fit,width wise.I have a set of 1"adaptors to fit the later model C4 wheels.I want to know ,before I import these wheels to Western Australia.
Thanks for any help and comments
Old Dec 31, 2013 | 06:53 PM
WVZR-1's Avatar
WVZR-1
You need to address each and every wheel that you're interested in on a "one at a time" evaluation. There's NOT an answer that will specifically answer your question. There's way to many choices. If you have a "specific" wheel dimension you're interested in it's not as difficult. You need to supply width and offset of those that interest you.
If you have 1" spacers presently you can likely buy with that in mind but it's a "one by one" application.
Supply width and offset maybe mentioning also the wheel diameter just for comparisons. What wheels do you have presently? Width and offset? Were you using your adapters? Were you happy with the tire/wheel placement?
Old Jan 1, 2014 | 07:26 AM
Apache 84's Avatar
Apache 84
I have the original wheels at present,(16"),looking for some 17"x8.5 &17x9.5 if possible,A mold type or C5 later type.
My offset at present is 36mm &38mm
To C5-C6 wheels on 84 C4
