my 84 corvette seems to run good then it runs a little ruff , it has throttle bodies, it just acts like its not getting gas but when i look its ideling good , please help me i havent been able to drive regular. scared its going to break down . is there any electric parts i need to check . my 87 had injection and i fixed all that . please help . i want 2 ride .
o2 sensor .driver side under the header ! first give her a overall service ! check timing , fuel pressure , bad cat ? , fuel spray ( no drops ) , bad egr valve , dirty iac, vacuum leaks,replace the fuel and air filters
